FireBeetle 2 ESP32-E (N16R2) IoT Board (Dual-Core 240MHz, WiFi/Bluetooth, LVGL Support)
$12.90
SKU: DFR1139
An IoT development board with 16M Flash, 2M PSRAM, dual-core processor, WiFi/Bluetooth support, numerous interfaces, and compact design for embedded projects.
The FireBeetle 2 ESP32-E is an IoT development board based on the ESP32-WROOM-32E-N16R2 module. It features a 240MHz dual-core processor, 16MB Flash, and 2MB PSRAM. The board supports 2.4GHz Wi-Fi (802.11 b/g/n) and Bluetooth 4.2 BR/EDR & BLE. It operates on 5V DC via USB-C or a 3.7V Li-ion battery, featuring automatic power switching and charging. Peripherals include 17 digital pins, 11 analog pins, 3x UART, 1x SPI, 1x I2C, and an onboard GDI for display connections. It is programmable with Arduino IDE, ESP-IDF, and MicroPython. The module measures 25.4mm x 60mm and utilizes an onboard PCB antenna for robust connectivity.
Features of ESP32-WROOM-32E-N16R2 module
Abundant peripheral interfaces
Including 17 digital pins, 11 analog pins, 3 UART interfaces, 1 SPI interface, 1 I2C interface, 1 I2S interface, and 2 DAC interfaces, it can meet various hardware connection needs.
Board Overview of FireBeetle 2 ESP32-E (N16R2) Development Board
Dual power supply modes
Supporting both USB and external 3.7V lithium battery power supply, it can automatically switch between power sources under dual power supply, and supports both USB and external DC charging modes.
Support for multiple programming methods
Including Arduino IDE, ESP-IDF, Micro-Python, etc., catering to different developers' programming habits.
Support Arduino IDE, ESP-IDF, Micro-Python
Compact design, convenient for embedding
With a size of only 25.4mm × 60mm, onboard WiFi and Bluetooth antennas, and using stamp hole design, it is convenient to embed or integrate into PCB prototypes.
The difference between ESP32-WROOM-32E and ESP32-WROOM-32UE
The ESP32-WROOM-32E (this product) uses an onboard PCB antenna. This type of antenna is realized through PCB technology, does not require separate antenna assembly, is not easily damaged by touch, and is convenient for whole machine assembly. Onboard antennas can save space, reduce costs, and because they can be carefully positioned on the board, they can provide signal integrity. However, their gain may be lower than that of external antennas.
The ESP32-WROOM-32UE, on the other hand, connects to an external antenna via a connector. External antennas can be installed on the outside of the device and include both omnidirectional and directional antenna types. The main advantage of external antennas is that they can provide higher gain, thereby enhancing the communication range of Bluetooth or WiFi.
Furthermore, this product is one of the low-power IoT development boards in the FireBeetle series. If it does not meet your requirements, you can refer to the FireBeetle Series Selection Guide to choose a more suitable model.
  • Equipped with ESP32-WROOM-32E-N16R2 dual-core module
  • Clock frequency up to 240MHz, with 16M Flash and 2M PSRAM for large memory capacity
  • Low-power development board, supporting dual-mode communication of WiFi and Bluetooth
  • Onboard GDI display interface for quick connection to display screens
  • Onboard charging circuit and PH2.0 lithium battery interface, supporting dual power supply and automatic switching
  • Supports various programming methods such as Arduino IDE, ESP-IDF, Micro-Python
  • Compact design, small size, suitable for space-limited and embedded IoT projects
  • Home automation renovation
  • Remote control of robots
  • Environmental data monitoring
  • Smart lighting control
  • Control panel UI design
IoT applications of FireBeetle 2 ESP32-E (N16R2) IoT Microcontroller
    Power Parameters
    Input Voltage
  • USB-C interface: 5V DC
  • PH2.0 interface: 3.7V Li-ion
  • VCC pin: 5V DC
  • MCU Parameters
  • Processor: Tensilica LX6 dual-core processor (one core for high-speed connectivity, one core for independent application development)
  • Clock Frequency: 240MHz
  • SRAM: 520KB
  • ROM: 448KB
  • Flash: 16MB
  • PSRAM: 2MB
  • On-chip Clock: 40MHz crystal oscillator, 32.768KHz crystal oscillator
  • Wireless Parameters
  • Wi-Fi Standard: FCC/CE/TELEC/KCC
  • Wi-Fi Protocol: 802.11 b/g/n/d/e/i/k/r (802.11n, up to 150 Mbps), A-MPDU and A-MSDU aggregation, supports 0.4us protection interval
  • Wi-Fi Frequency Range: 2.4~2.5 GHz
  • Bluetooth Protocol: Compliant with Bluetooth V4.2 BR/EDR and BLE standards
  • Bluetooth Audio: CVSD and SBC audio
  • Bluetooth Frequency Range: 2.4~2.5GHz
  • Peripheral Parameters
  • Digital Pins × 17: IO0, IO1, IO2, IO3, IO4, IO12, IO13, IO14, IO15, IO17, IO18, IO19, IO21, IO22, IO23, IO25, IO26
  • Analog Pins × 11: IO0, IO2, IO4, IO12, IO13, IO14, IO15, IO25, IO26, I34, I35
  • UART Interfaces: ×3
  • SPI Interface: ×1
  • I2C Interface: ×1
  • I2S Interface: ×1
  • DAC Interface: ×2
  • Touch Interfaces: ×7
  • LED PWM Channels: ×16
  • RGB_LED: WS2812
  • Display Interface: GDI
  • Other Parameters
  • Interface Compatibility: FireBeetle V2 series compatible
  • Module Size: 25.4mm × 60mm
  • Weight: 23.4g
  • FireBeetle 2 ESP32-E (N16R2) IoT Microcontroller x1
  • 18pin-2.54mm Pitch Pin x1
  • 18pin-2.54mm Pitch Pin Female x1
  • 14pin-2.54mm Pitch Pin x1
  • 14pin-2.54mm Pitch Pin Female x1
FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
Blog FireBeetle V1 vs V2 (ESP32/ESP8266/Arduino) Development Board Selection Guide
Jun 08, 2025
Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Blog Comparisons between FireBeetle ESP32, ESP8266, ESP32 C6, and ESP32 S3
Sep 25, 2023
Turn Any Drone Into A Delivery Drone
Projects Turn Any Drone Into A Delivery Drone
Iloke alusala
Jun 27, 2025
David. Feb 09, 2026
Excellent value product
Muhammad Fadil.Huseiny Oct 30, 2025
Good, the product shipped on time
