The FireBeetle 2 ESP32-UE is an IoT microcontroller based on the ESP32-WROOM-32UE-N16R2 module, featuring a connector for an external WiFi/Bluetooth antenna. It is equipped with a Tensilica LX6 dual-core processor (240MHz), 16MB Flash, and 2MB PSRAM. It supports dual-mode communication via 2.4GHz Wi-Fi (802.11 b/g/n) and Bluetooth 4.2 (BR/EDR/BLE). The board operates on a 5V DC (USB-C) or 3.7V Li-ion battery, with automatic power switching and charging. Peripherals include 17 digital pins, 11 analog pins, 3x UART, 1x I2C, 1x SPI, and an onboard GDI for display connections. It is programmable with Arduino IDE, ESP-IDF, and MicroPython.
Based on Espressif’s ESP32-WROOM-32UE-N16R2 module, this product features a 32-bit dual-core processor with a clock frequency of up to 240MHz and supports MCU, WiFi, and Bluetooth dual-mode communication. It is highly suitable for a wide range of IoT scenarios.
Rich peripheral interfaces
Including 17 digital pins, 11 analog pins, 3 UART interfaces, 1 SPI interface, 1 I2C interface, 1 I2S interface, and 2 DAC interfaces, it can meet various hardware connection requirements.
Dual power supply modes
Supporting USB and external 3.7V lithium battery power supply, it can automatically switch between power sources in dual power supply mode. It also supports USB and external DC charging modes.
Support for multiple programming methods
Including Arduino IDE, ESP-IDF, MicroPython, etc., catering to the programming preferences of different developers.
Compact design, easy to embed
With dimensions of only 25.4mm × 60mm and a stamp hole design, it is easy to embed or integrate into PCB prototypes.
The difference between ESP32-WROOM-32E and ESP32-WROOM-32UE
The ESP32-WROOM-32E uses an onboard PCB antenna. This type of antenna is realized through PCB technology, does not require separate antenna assembly, is not easily damaged by touch, and is convenient for whole machine assembly. Onboard antennas can save space, reduce costs, and because they can be carefully positioned on the board, they can provide signal integrity. However, their gain may be lower than that of external antennas.
The ESP32-WROOM-32UE (this product), on the other hand, connects to an external antenna via a connector. External antennas can be installed on the outside of the device and include both omnidirectional and directional antenna types. The main advantage of external antennas is that they can provide higher gain, thereby enhancing the communication range of Bluetooth or WiFi.
Furthermore, this product is one of the low-power IoT development boards in the FireBeetle series. If it does not meet your requirements, you can refer to the FireBeetle Series Selection Guide to choose a more suitable model.
Power Parameters - Input Voltage
MCU Parameters
Wireless Parameters
Peripheral Parameters
Other Parameters
Nov 07, 2025
An excellent upgrade from the classic ESP32 boards! The FireBeetle 2 ESP32-UE offers impressive performance with its 16 MB flash and 2 MB PSRAM — perfect for demanding IoT or AI applications. The external antenna support significantly improves Wi-Fi range and stability, which is ideal for remote or industrial environments. It’s easy to program via Arduino IDE or PlatformIO, and runs smoothly with multiple sensors. Compact, efficient, and well-designed — a great choice for professional IoT development.
Nov 05, 2025
Good working stable as intended
Jan 10, 2025
Perfect microcontroller for various MicroPython projects. The external antenna enables much better transmission and reception performance in WLAN (compared to onboard antennas).
