Direct-Drive Servo Motor for Robotics and AGV Drive Wheel (UART, 210rpm) V2.0
$29.90
SKU: FIT1001
  • $29.00 3+ items
  • $28.00 5+ items
  • $27.00 10+ items
Compact direct-drive servo motor with integrated design, low noise, high precision, and advanced communication. Ideal for robotics and educational applications.
The direct-drive servo motor is a high-reliability permanent magnet synchronous motor that integrates an outer rotor brushless motor, an encoder, and a servo drive. Using advanced direct-drive technology, this motor eliminates the need for a traditional reducer, transforming a noisy and inefficient system into a compact, efficient, and quiet one.
The upgraded V2.0 offers a wider working voltage range of 11-28V DC, a rated torque of 0.25 Nm, a stalling torque of 0.85 Nm, and a reduced stall current of ≤3A for more stable and reliable performance. Furthermore, the newly added IPX4 waterproof rating makes it suitable for humid environments or applications with a risk of splashing water. Combined with the high-precision sensor built into the motor and the FOC control algorithm used by the driver, it is ideal for applications such as robot joints, balance car drive wheels, small AGV drive wheels, and educational robots.
direct-drive servo motor features
Integrated Design
The direct-drive servo motor features an integrated design that combines the motor and driver, providing high integration and a compact structure. This design enables the motor to deliver smooth torque, stable speed, and precise position control without an external reducer.
Stable and Quiet Operation
Thanks to the brushless motor design and FOC control algorithm, the motor boasts low-noise operation and a long service life. It maintains smooth and quiet performance even under load, making it suitable for applications where noise is a concern.
The brushless motor design ensures low noise
High Precision and Safety
Equipped with a high-precision sensor and the FOC control algorithm, the motor achieves precise control. The driver includes a comprehensive monitoring mechanism and protection functions, such as over-current, over-temperature, and stall protection (with an improved stall current of ≤3A), ensuring safe and reliable operation.
Advanced Communication and Control
The motor supports Hall position detection and electric braking. It can communicate via UART to provide real-time position, speed, current, and fault code information. This feature allows for detailed monitoring and control, enhancing the reliability and efficiency of the motor in various applications.
Version Update Notice - V2.0 (10/7/2025):
This direct-drive servo motor has been upgraded to V2.0. Please note the following key improvements:
  • Performance: Voltage range expanded to 11-28V; stall current reduced to ≤3A.
  • Durability: Now features an IPX4 waterproof rating.
  • Structure: Updated appearance, weight is now 260g.
  • V1.0 users can still find original documentation or contact support.
    The brushless motor version update
  • Integrated design of motor and driver, high integration
  • Fast response, direct drive without delay
  • Brushless motor, low noise, long life
  • Supports Hall position detection, electric brake
  • Enhanced over-current, over-temperature, and stall protection (Stall current ≤3A)
  • Driver FOC control algorithm with a built-in high-precision sensor
  • Expanded working voltage range: 11~28V DC
  • New IPX4 waterproof rating
  • Access to motor's position, speed, current, and fault code via UART communication
  • Robot joints
  • Balance car drive wheels
  • Small AGV drive wheels
  • Toy drive wheels
  • Educational cars
  • Working voltage range: 11~28V DC
  • Communication method: UART
  • No-load speed: 210±15 rpm
  • No-load current: 0.15 A
  • Rated speed: 98 rpm
  • Rated torque: 0.25 Nm
  • Rated current: 0.5 A
  • Maximum efficiency: ≥50%
  • Stalling torque: 0.85 Nm
  • Stalling current: ≤3 A
  • Rated voltage: 14.4V DC
  • Torque constant: 0.28 Nm/A (98 rpm)
  • Speed constant: 14 rpm/V
  • Working temperature: -5°C~40°C
  • Motor weight: 260 g
  • Encoder resolution: 12 bit
  • Noise level: ≤48 dB
  • Protection level: IPX4
  • Direct Drive Servo Motor-UART 210rpm (V2.0) x1
