Voice Prompt Module with Integrated MP3 Player and Speaker
$7.90
SKU: DFR1173
  • $7.80 3+ items
  • $7.60 5+ items
  • $7.40 10+ items
The compact voice prompt module supports MP3, WAV, WMA formats, offers 16MB storage, and easy control via buttons or serial commands for versatile applications.
The voice prompt module integrates an intelligent MP3 music playback chip with a speaker. Designed for ease of use, it can operate directly with a power supply, battery, and buttons, or be controlled via serial commands. Featuring seamless MP3, WAV, and WMA hardware decoding, this module boasts a 16MB memory capacity, enabling easy playback of specified tracks and sequences through simple serial commands. Its user-friendly design, wide applicability, good sound quality, and reliable performance make it superior to previous MP3 player and speaker solutions.
high integration voice prompt module
Compact Design
Measuring just 30*11mm, the module's compact design allows for easy installation in space-constrained applications. Despite its small size, it delivers powerful audio output with a 1W speaker and 4Ω impedance.
voice prompt module compact design
High-Quality Audio Playback
With support for MP3, WAV, and WMA file formats, and a high-quality DAC output, the module ensures excellent sound quality. This is crucial for applications where clear audio playback is essential.
Robust Storage and Operation
The module features 16MB of internal storage, ensuring reliable long-term storage of MP3 files even when power is lost. It operates efficiently within a temperature range of -20℃ to +70℃, making it suitable for diverse environments.
Easy Integration and Control
The module can be directly powered and controlled using simple buttons or serial commands, making it easy to integrate into various systems without the need for complex programming. The TTL level serial communication interface simplifies the control process.
Versatile Applications
The voice prompt module is ideal for a range of applications, including car navigation, public transport safety announcements, financial business hall voice prompts, and many more. Its versatility makes it suitable for any scenario requiring clear and reliable voice prompts.
  • Car Navigation Voice Broadcast: Enhances driving experience with clear navigation prompts.
  • Public Transport Safety Announcements: Provides safety prompts at railway stations and bus stops.
  • Financial Business Halls: Assists in customer service with voice prompts.
  • Security and Inspection: Used in security checks and toll stations for clear instructions.
  • Public Safety and Alerts: Essential in public security, fire alarms, and equipment failure notifications.
  • Tourist and Transport Vehicles: Ensures safety with driving notices and operational guides.
  • Power supply voltage: DC 5V
  • Output power: 1W
  • Speaker impedance: 4Ω
  • File format: MP3/WAV
  • Trigger mode: TTL level serial communication/1-channel switch
  • Trigger functions for P1 interface:
              Short press: Next track
              Double press: Previous track
              Long press: Pause/Play
  • Storage capacity: 16M
  • Operating temperature: -20℃ to +70℃
  • Dimensions: 30*11mm
  • MP3 voice prompt module × 1
  • USB to 4-pin DuPont cable × 1
    How to Choose the Best MP3 Player Module for Your Arduino / DIY Project (2025 Selection Guide)
    Blog How to Choose the Best MP3 Player Module for Your Arduino / DIY Project (2025 Selection Guide)
    Sep 21, 2025
    Chaos Gift Build: Moving House & Making a Toilet Talk
    Projects Chaos Gift Build: Moving House & Making a Toilet Talk
    Mellow_Labs
    Jul 14, 2025
    Evan.Levy Mar 11, 2026
    Absolutely amazing upgrade from the DFPlayer Mini! I love that the module is enclosed in a speaker housing, it makes integration much cleaner and protects the hardware. I’ll definitely be ordering more. The I/O layout could be improved. The male header pins sit in the center of the back of the board, which means you have to design around them when integrating the module. Exposed pads or through-hole mounting holes would make installation much easier. Even simply extending the PCB slightly beyond the speaker housing to allow for through-hole mounts would help. A small JST connector could also be nice, though that would likely add cost and complexity. As it stands, the pins can bend easily, the spacing is a bit tight, and the layout feels slightly awkward when building it into a project. (My opinion) That said, it’s still a great product and a really quick, clean way to add sound to your projects. Tip: Read the manual before using it, there are a few details worth knowing before wiring it up.
