The Raspberry Pi Pico 2 W is a low-cost, highly flexible development platform designed around the RP2350 microcontroller. It integrates essential components like 4 MB of flash memory, a 2.4GHz wireless interface supporting Wi-Fi 802.11n and Bluetooth 5.2, and a comprehensive set of general-purpose I/O pins. The platform offers multiple power supply options and supports both micro USB and external sources, making it suitable for a wide range of IoT applications. With its versatile design, users can choose between using the Pico 2 W as a module for surface mounting or with traditional pin headers, making it ideal for both prototyping and production use.
Wireless Connectivity and Versatility
The Raspberry Pi Pico 2 W is equipped with a powerful 2.4GHz wireless interface, including support for Bluetooth Low Energy (LE) and Classic Bluetooth, as well as Wi-Fi. This makes it an excellent choice for projects requiring wireless communication, such as IoT devices, home automation systems, and wireless sensor networks.
Rich I/O Options for Customization
With 26 multifunctional GPIO pins, including 3 capable of analog-to-digital conversion (ADC), the Pico 2 W offers extensive options for interfacing with sensors, actuators, and other peripherals. It also features a 3-pin Arm serial wire debug (SWD) port, enabling easy debugging and development. The platform’s flexible I/O layout, along with the castellated edges, allows for both through-hole pin headers and surface-mount configurations.
High Performance at Low Cost
Powered by the dual-core RP2350 microcontroller, the Pico 2 W is capable of running at up to 150MHz, delivering powerful performance for embedded applications. The system also benefits from a high-performance SRAM and external Quad-SPI flash memory, ensuring quick data processing and reliable performance in time-sensitive applications like data logging and real-time monitoring.
Raspberry Pi Pico 2 W vs. Raspberry Pi Pico 2: How to Choose
The difference between the Raspberry Pi Pico 2 W and the Raspberry Pi Pico 2 is the inclusion of wireless connectivity in the Pico 2 W.
The Raspberry Pi Pico 2 W is recommended for customers who need built-in wireless capabilities for their projects, such as IoT devices, wireless sensor networks, or home automation systems.
The Raspberry Pi Pico 2 is best suited for customers who do not need wireless connectivity.
Pin Definition Diagram of Raspberry Pi Pico 2 W
Microcontroller
I/O and Expansion
Power and Supply
Key Peripherals
Additional Features
Development Support
Mar 29, 2025
The controller for handy projects
Mar 03, 2025
The product is as shown in the picture, well-packaged, delivered quickly, and the store provided continuous updates on the delivery status. The service is great, and I am very satisfied.
