Raspberry Pi Compute Module 5 (4GB RAM, 32GB eMMC, 2.4 / 5.0 GHz Wireless, CM5104032)
$129.00
SKU: DFR1210
Notice: Limited to 2 pieces per customer.
Compact system-on-module with quad-core processor, up to 8GB RAM, 64GB storage, Gigabit Ethernet, Wi-Fi, Bluetooth, multiple I/O interfaces, and customizable PCB design.
Purchase this product and earn 1290 reward points, which are tied to VIP membership program. Learn More >
Raspberry Pi Compute Module 5 (CM5) delivers the performance of the Raspberry Pi 5 in a compact system‑on‑module format tailored for embedded design and industrial integration. Built around the Broadcom BCM2712 quad‑core Cortex‑A76 processor running at 2.4GHz, this high‑performance computing module provides scalable configurations with up to 8GB RAM and 64GB eMMC storage. Rich connectivity including Gigabit Ethernet, Wi‑Fi 5, Bluetooth 5.0, and extensive I/O makes this embedded computing platform suitable for custom carrier boards. The compact SoM architecture enables powerful processing capabilities within space‑constrained devices and specialized hardware systems.
Desktop‑Class Processing for Embedded Applications
Powered by the Broadcom BCM2712 64‑bit Arm Cortex‑A76 processor clocked at 2.4GHz, this embedded computing module delivers performance comparable to desktop‑class single‑board computers while maintaining a compact industrial form factor. Configurations offering 2GB to 8GB RAM and up to 64GB of eMMC storage support demanding workloads such as AI inference, multimedia processing, and real‑time data analysis. Such processing capability enables advanced edge computing systems, intelligent devices, and high‑performance automation platforms requiring reliable computing resources in embedded environments.
Extensive Connectivity and High‑Speed Interfaces
This system‑on‑module integrates a broad set of high‑speed interfaces designed for flexible system expansion. Gigabit Ethernet provides fast and reliable network connectivity, while dual USB 3.0 ports and a USB 2.0 interface allow integration of external peripherals and storage. Dual HDMI 2.0 outputs support simultaneous 4Kp60 video, enabling advanced multimedia systems or multi‑display digital signage. Additional MIPI interfaces support cameras and displays for vision or HMI applications, while certified Wi‑Fi 5 and Bluetooth 5.0 deliver dependable wireless communication for connected devices and IoT deployments.
Custom Carrier Board Integration
Unlike fixed‑interface single‑board computers, this compute module platform enables developers to design custom carrier boards tailored to specific system requirements. The modular architecture allows precise control over I/O routing, connectors, and peripheral integration, making the hardware well suited for industrial controllers, smart appliances, robotics platforms, and dedicated edge computing systems. Compatibility with development kits simplifies early prototyping and accelerates product development, allowing engineers to move quickly from concept to production‑ready embedded solutions.
Such a compact high‑performance compute module fits a wide range of embedded and industrial deployments, including intelligent edge devices, multimedia terminals, machine vision systems, and advanced IoT controllers. The flexible SoM architecture combined with powerful processing and versatile connectivity makes this embedded computing platform suitable for scalable product development across prototyping, commercialization, and long‑term industrial deployment.
  • Broadcom BCM2712 quad‑core 64‑bit Arm Cortex‑A76 processor running at 2.4GHz
  • 4GB RAM with integrated 32GB eMMC storage
  • Compact 55 mm × 40 mm system‑on‑module form factor for embedded integration
  • Gigabit Ethernet with IEEE 1588 support
  • Dual USB 3.0 ports supporting simultaneous 5Gbps operation
  • Single USB 2.0 high‑speed interface
  • Dual HDMI 2.0 outputs supporting simultaneous 4Kp60 video
  • Dual 4‑lane MIPI interfaces supporting both DSI displays and CSI‑2 cameras
  • Certified Wi‑Fi 5 (802.11ac) and Bluetooth 5.0 wireless connectivity
  • Up to 30 GPIO pins with multiple peripheral interface options
  • PCIe Gen2 x1 interface for high‑speed expansion
  • Designed for custom carrier boards and embedded product development
  • Embedded systems
  • Raspberry Pi Compute Module 5 is already being deployed in successful embedded solutions
    Figure: Raspberry Pi Compute Module 5 is already being deployed in successful embedded solutions
  • Form Factor: 55 mm × 40 mm × 4.7 mm module, 4 × M2.5 mounting holes
  • Processor: Broadcom BCM2712 quad-core 64-bit Arm Cortex-A76 (Armv8) SoC @ 2.4GHz
  • Memory: 4GB RAM, 32GB eMMC
  • Connectivity:
    Certified radio module containing:
  • 2.4 GHz / 5.0 GHz IEEE 802.11 b/g/n/ac wireless
  • Bluetooth 5.0, BLE
  • On-board electronic switch to select between PCB trace or external antenna
  • Network:
  • Gigabit Ethernet PHY supporting IEEE 1588
  • 1 × PCIe x1 root complex, Gen 2 (5Gbps)
  • 1 × USB 2.0 port (high speed)
  • 2 × USB 3.0 ports, supporting simultaneous 5Gbps operation
  • GPIO Interfaces (Up to 30 × GPIO supporting either 1.8V or 3.3V signalling and peripheral options):
  • Up to 5 × UART
  • Up to 5 × I2C
  • Up to 5 × SPI
  • 1 × SDIO interface
  • 1 × DPI (parallel RGB display)
  • 1 × I2S
  • Up to 4 × PWM channels
  • Up to 3 × GPCLK outputs
  • Video:
  • 2 × HDMI 2.0 ports (supports up to 4Kp60 on both ports simultaneously)
  • 2 × 4‑lane MIPI ports supporting both DSI (display port) and CSI‑2 (camera port)
  • Multimedia: 4Kp60 HEVC decoder, OpenGL ES 3.1 graphics, Vulkan 1.2, 1 × SDIO 2.0 (CM5 Lite)
  • Input Power: Single +5V PSU input supports USB PD for up to 5A @ 5V
  • Operating temperature: -20°C to +85°C
  • MTBF Ground Benign: 143 000 hours (168 000 hours CM5 Lite)
  • Production lifetime: Raspberry Pi Compute Module 5 will remain in production until at least January 2036
  • Raspberry Pi Compute Module 5 (Wireless, 4GB RAM, 32GB eMMC) ×1
    New Raspberry Pi Compute Module 5 Review and Guide for Embedded Systems
    Blog New Raspberry Pi Compute Module 5 Review and Guide for Embedded Systems
    Nov 27, 2024
    TAKAO.SAKAMOTO May 31, 2025
    Nice performance but temperature is high. I use heat sink with fan.
    Notify Me Notify me when available
