Raspberry Pi Cooler for Compute Module 5
$5.00
SKU: FIT1015
Notice: Limited to 1 pieces per customer.
Passive heatsink for Compute Module 5 enhances CPU performance and prevents damage, with optimal heat dissipation using thermally conductive silicone.
The Raspberry Pi Cooler for Raspberry Pi Compute Module 5 is a passive heatsink that helps Compute Module 5 dissipate heat, improving CPU performance, and protects it from mechanical damage.
Thermally conductive silicone on the underside of the Cooler effectively couples it to the surface of the Compute Module 5 CPU, wireless module, and power management chip for optimal heat dissipation.
Raspberry Pi Cooler and Raspberry Pi Compute Module 5
Figure: Raspberry Pi Cooler and Raspberry Pi Compute Module 5
Install the Raspberry Pi Cooler
Figure: Install the Raspberry Pi Cooler
Mechanical diagram of the Raspberry Pi Cooler
Figure: Mechanical diagram of the Raspberry Pi Cooler
  • Form factor: 56mm×41mm×12.7mm
  • Product material: Aluminium profile, thermally conductive silicone
  • Production lifetime: The Raspberry Pi Cooler for Raspberry Pi Compute Module 5 will remain in production until at least January 2036
  • Compliance: For a full list of local and regional product approvals, please visit pip.raspberrypi.com
  • Raspberry Pi Cooler for Compute Module 5 x1
  • Only 6 Left
