Raspberry Pi Compute Module 5 IO Case with DC Brushless Fan
$15.00
SKU: FIT1014
Notice: Limited to 1 pieces per customer.
High-quality metal case for Compute Module 5 and IO Board, with slots for accessories and connectors, built-in fan for cooling, and space for external antenna.
Purchase this product and earn 150 reward points, which are tied to VIP membership program. Learn More >
The Raspberry Pi IO Case is a high-quality two-piece metal enclosure for Raspberry Pi Compute Module 5 and the Compute Module 5 IO Board. It provides space for accessories connected to the IO Board, such as an M.2 SSD or a PoE+ HAT+.
The IO Case includes slots to enable the connection of CSI-2 cameras or DSI displays and includes a built-in controllable fan to support thermal regulation for higher-power applications. Cut-outs in the side of the case allow access to HDMI, Ethernet, USB-A, and USB-C (power-in) connectors and to the SD card slot. A mounting hole is provided for an external wireless antenna.
Assembly instructions for Raspberry Pi IO Case
Figure: Assembly instructions for Raspberry Pi IO Case
Case
  • Form factor: 170mm×94mm×28 mm
  • Weight: Approx 350g
  • Product material: Sheet metal
  • DC brushless fan
  • Input voltage: 5V DC (3.5-5.5V) supplied via four-pin fan header on a carrier board
  • Start voltage: ≥ 3.5V
  • Power consumption: 0.85W
  • Rated current: 0.18 ± 0.02A
  • Fan speed control: Pulse width modulation control with tachometer
  • Maximum fan speed: 8000 RPM ± 15% (at 25℃, after 3–5 minutes rotating)
  • Maximum airflow: 2.46 CFM
  • Noise: 21.7 dB
  • Cable length: 150 mm
  • Production lifetime: The Raspberry Pi IO Case will remain in production until at least January 2036
  • Compliance: For a full list of local and regional product approvals, please visit pip.raspberrypi.com
  • Raspberry Pi Compute Module 5 IO Case x1
  • Only 10 Left
