The Raspberry Pi Compute Module 5 IO Board (CM5IO) is a versatile development tool designed to integrate the Raspberry Pi Compute Module 5 (CM5) into various products, particularly for industrial and embedded applications. Its robust connectivity options, including full-size HDMI, Gigabit Ethernet, and USB ports, make it suitable for projects requiring high processing power and extensive peripheral integration. With support for PoE+ and additional expansion through M.2 PCIe cards, the CM5 IO board is highly adaptable to various use cases, including IoT devices, network appliances, and custom computing solutions.
Figure: Raspberry Pi Compute Module 5 IO Board and CM5
Wide Compatibility and Expansion Options
The CM5IO board supports all Compute Module 5 variants, ensuring compatibility across different product designs. The M.2 M Key PCIe socket and HAT+ connector offer ample expansion possibilities, allowing engineers to customize their systems with additional storage, networking, and other peripherals.
Rich Connectivity
Featuring two full-size HDMI 2.0 connectors, Gigabit Ethernet with PoE+ support, and multiple USB 3.0 ports, the CM5IO board provides a comprehensive set of connectivity options. These features ensure seamless integration with a variety of devices and networks, making the board suitable for both consumer and industrial use cases.
Flexible Power Management
The board is powered via an external +5V USB-C PSU, with a dedicated power button for easy wake-up and shutdown of the Compute Module 5. This functionality ensures that the system can be managed efficiently in embedded and industrial environments.
Connectivity:
Power Input:
May 31, 2025
Easy install and the quality is good.
