Raspberry Pi Compute Module 5 IO Board
$20.00
SKU: DFR1211
Notice: Limited to 1 pieces per customer.
The CM5IO board is a versatile tool for integrating the Compute Module 5 into industrial applications, offering HDMI, Ethernet, USB, PoE+, and expansion options.
Purchase this product and earn 200 reward points, which are tied to VIP membership program. Learn More >
The Raspberry Pi Compute Module 5 IO Board (CM5IO) is a versatile development tool designed to integrate the Raspberry Pi Compute Module 5 (CM5) into various products, particularly for industrial and embedded applications. Its robust connectivity options, including full-size HDMI, Gigabit Ethernet, and USB ports, make it suitable for projects requiring high processing power and extensive peripheral integration. With support for PoE+ and additional expansion through M.2 PCIe cards, the CM5 IO board is highly adaptable to various use cases, including IoT devices, network appliances, and custom computing solutions.
Raspberry Pi Compute Module 5 IO Board and CM5
Figure: Raspberry Pi Compute Module 5 IO Board and CM5
Wide Compatibility and Expansion Options
The CM5IO board supports all Compute Module 5 variants, ensuring compatibility across different product designs. The M.2 M Key PCIe socket and HAT+ connector offer ample expansion possibilities, allowing engineers to customize their systems with additional storage, networking, and other peripherals.
Rich Connectivity
Featuring two full-size HDMI 2.0 connectors, Gigabit Ethernet with PoE+ support, and multiple USB 3.0 ports, the CM5IO board provides a comprehensive set of connectivity options. These features ensure seamless integration with a variety of devices and networks, making the board suitable for both consumer and industrial use cases.
Flexible Power Management
The board is powered via an external +5V USB-C PSU, with a dedicated power button for easy wake-up and shutdown of the Compute Module 5. This functionality ensures that the system can be managed efficiently in embedded and industrial environments.
  • IoT devices
  • Network appliances
  • Custom computing solutions
  • Form Factor: 160mm x 90mm
  • Connectivity:
  • Standard 40-pin GPIO header
  • Gigabit Ethernet (RJ45) with PoE+ and HAT+ support
  • 2 x USB 3.0 Type-A ports
  • microSD card socket (for Compute Module 5 Lite)
  • M.2 M-Key PCIe socket
  • 4-pin fan connector
  • 2 x MIPI DSI/CSI-2 FPC connectors (22-pin, 0.5mm pitch)
  • Raspberry Pi HAT+ connector
  • RTC (Real-Time Clock) battery socket
  • Power Input:
  • External +5V USB-C PSU
  • Power button for wake and shutdown of Compute Module 5
  • Video Output: 2 x Full-size HDMI 2.0 connectors
  • MTBF (Mean Time Between Failures): 131,000 hours (Ground Benign Environment)
  • Production Lifetime: Available until at least January 2028
  • Compliance: For a full list of local and regional product approvals, visit pip.raspberrypi.com
  • Raspberry Pi Compute Module 5 IO Board x1
  • Review
    TAKAO.SAKAMOTO May 31, 2025
    Easy install and the quality is good.
    Only 13 Left
