The UNIHIKER K10 is not just a coding board; it is a gateway to the physical AI revolution. Designed for K12 STEM education, beginners, and advanced makers, it combines vision AI, voice control, and TinyML machine learning in one compact device. Powered by the ESP32-S3, this AI terminal bridges the gap between Cloud Large Language Models (LLMs) and the physical world. Featuring a 2.8-inch color display, dual wireless connectivity (Wi-Fi/Bluetooth), and a comprehensive sensor suite (2MP camera, microphone, speaker, RGB light, plus environmental detectors), the UNIHIKER K10 is the ultimate hardware carrier. Whether building an offline Vision AI monitor, a DeepSeek-powered voice assistant, or an autonomous smart home system, the UNIHIKER K10 makes cutting-edge AI tangible without requiring complex wiring. As an officially supported hardware platform for ESP-CLAW AI Agent, the custom firmware can be easily flashed to transform it from a traditional development board into an autonomous AI terminal.
4 Pre-Loaded Vision AI Models for Beginner Projects
Ideal for first-time AI exploration, the UNIHIKER K10 board comes with four ready-to-use vision models: Face Detection, Pet Recognition (Cat/Dog), QR Code Scanning, and Motion Sensing. The integrated 2MP camera allows beginners to immediately create security systems, interactive displays, and smart monitoring projects - no prior programming experience needed.
Supports Offline Speech Recognition
Equipped with a built-in microphone and pre-installed voice models, the UNIHIKER K10 supports offline speech recognition. This enables users to create voice-activated applications, such as custom voice commands and interactive AI systems, without requiring an internet connection.
Not Just Built-in Models
The UNIHIKER K10 supports TinyML, allowing users to train their own custom vision and sensor models. With the ability to develop personalized AI models for specific tasks, users can explore deeper AI applications and tailor the board’s functionality to their unique projects. Whether working with image recognition, sensor data, or other AI-based tasks, TinyML offers the flexibility to push the boundaries of the board’s capabilities.
Combine BT & Wi-Fi with AI to Create More Possibilities
By combining Bluetooth 5.0 and Wi-Fi 2.4G with onboard AI functionality, the UNIHIKER K10 offers extensive connectivity options for creating more interactive and data-driven applications. Whether building IoT systems, remote control applications, or data transmission projects, the UNIHIKER K10 provides seamless integration of AI with wireless communication protocols.
Support the Internet of Things
The UNIHIKER K10 is designed with IoT applications in mind. It supports long-term data collection and remote monitoring, making it ideal for projects that require continuous data recording and analysis. With its rich set of sensors (temperature, humidity, light, accelerometer) and connectivity options (Wi-Fi, Bluetooth), users can easily integrate the UNIHIKER K10 into IoT ecosystems for real-time monitoring, remote device control, and data-driven applications.
Pair it with the Gravity: BME688 AI Environmental Sensor (VOC, Temperature, Humidity, Pressure) to create advanced air quality monitoring projects.
Built-in 2.8-inch Color Screen for Data Visualization
The UNIHIKER K10 features a 2.8-inch color screen that enables users to visualize real-time data from sensors, AI models, and projects. This screen is ideal for displaying sensor readings, AI outputs, and project results directly on the board, providing immediate feedback.
Rich Interfaces and High Expandability
With an array of I/O ports, including USB Type-C, MicroSD, Gravity 3pin/4pin, and edge connectors, the UNIHIKER K10 offers rich expandability for connecting additional sensors, actuators, and accessories.
Supports Graphical and MicroPython Programming
The UNIHIKER K10 supports both graphical programming and MicroPython, catering to users at different skill levels. It is also compatible with Mind+, a drag-and-drop programming tool that simplifies coding with blocks. The graphical programming interface allows beginners to quickly build projects without needing to write code, while MicroPython offers a more advanced programming environment for experienced developers.
The tool also offers a variety of sample projects to help users get started, such as:
For more hands-on tutorials, visit the Examples link to explore a wide range of projects.
Download Mind+ to get started: Mind+ Download.
Officially Supported by ESP-CLAW: Play with Your AI Agent
The UNIHIKER K10 delivers the "Command. Realize." workflow as an officially supported hardware platform for the ESP-CLAW framework. By simply flashing the firmware, the UNIHIKER K10 turns into an AI Agent, enabling the control of physical hardware using natural language via chat apps (like Telegram). Instead of manual coding, the AI Agent automatically calls tools, writes scripts, and executes them on the board. Acting as a powerful data pipeline for external APIs (via MCP), it seamlessly connects Cloud LLMs to physical sensors. The new released step-by-step tutorial are available to guide the firmware flashing process and initiate the AI Agent.
UNIHIKER Selection Guide
Video: Introduction and Feature Demonstration of UNIHIKER K10
![[ESP‑Claw + UNIHIKER K10]: Build an Adaptive AI Ambient Light with Zero Code and Low Cost](https://dfimg.dfrobot.com/096206e5feba41d6800160bc9c0013c5/community/80a911c44dbd010ecb77279bd2175b0e_924x560.PNG.webp)
Projects [ESP‑Claw + UNIHIKER K10]: Build an Adaptive AI Ambient Light with Zero Code and Low Cost
Jan 06, 2026
This one is just amazing ! I use one core to handle UDP communications (high priority) and servo control, and the other core for low priority tasks (web server and /UI on screen). The presence of screen on a ESP32 based board opens door to lot of fun. In term of dev environment, platform.io facilitate your life. I've not used yet the micro ml stuff.
Apr 24, 2026
Excellent technology.
Dec 02, 2025
Beginner friendly and powerful at the same time! K10 does vision, voice, pin control, audio, and an array of sensors out of the box. I paired it with Maqueen robot and it is a dream to get AI projects working and roaming your space! I have used M10 and K10 and this is much easier to use and has similar functionality. If you are willing to forego the processor and touchscreen on the M10, this is a better choice (and cheaper!)
