DC-DC Step Down Buck Converter (6~24V to 5V/16A)
$12.90
SKU: DFR1202
  • $12.50 3+ items
  • $12.30 5+ items
  • $11.90 10+ items
A DC-DC converter module with 6-24V input, 5V output, 16A max current, 90% efficiency, low ripple, and protection features for robotics and electronics.
This DC-DC step-down converter module is designed to provide reliable power conversion with high efficiency. It accepts a wide input voltage range from 6V to 24V and provides a stable 5V output, supporting up to 16A of current. The module is equipped with key features such as over-temperature protection (up to 125°C), output short circuit protection, and an output ripple noise of less than 20mV. Achieving conversion efficiency greater than 90% under typical conditions (12V input with 1-16A load), this module is ideal for applications that require a stable and efficient power supply, such as driving multiple motors or servos in robotics, high-power LED lighting systems, automotive electronics and DC-powered devices, smart robots, drones.
High Efficiency and Low Ripple
The module achieves a conversion efficiency of over 90% with a 12V input and 1-16A load, ensuring minimal energy loss. Its output ripple noise is maintained below 20mV, making it suitable for sensitive electronic devices and precision applications.
Robust Protection Mechanisms
Equipped with 125℃ over-temperature protection and output short-circuit protection, the module ensures reliable operation even under harsh conditions. These features safeguard both the module and connected devices from potential damage.
Enhanced Heat Dissipation
A thermal pad on the back of the module allows for soldering to a large copper area, significantly improving heat dissipation capabilities. This design ensures stable performance even during prolonged high-current operation.
The module features three control pins:
Pin and Dimension Diagram of DC-DC step-down converter module
Figure: Pin and Dimension Diagram of DC-DC step-down converter module
  • EN: Enables or disables the output when connected to a microcontroller's IO pin (with a 1K resistor in series).
  • AGND: Provides a single ground point for microcontroller control.
  • PGOOD: Outputs a high level (5V) when the output voltage is normal and a low level (0V) during abnormal conditions or short circuits.
  • Conversion Efficiency
    Conversion efficiency (Input 12V, output 5V, with a load ranging from 1 to 16A)
    Figure: Conversion efficiency (Input 12V, output 5V, with a load ranging from 1 to 16A)
    Conversion efficiency (Input 24V, output 5V, with a load ranging from 1 to 16A)
    Figure: Conversion efficiency (Input 24V, output 5V, with a load ranging from 1 to 16A)
  • Smart Robotics: Powering multiple actuators and sensors.
  • Drone Systems: Driving ESCs and onboard electronics.
  • High-Power LED Lighting: Ensuring stable and uniform illumination.
  • Automotive Electronics: Supporting auxiliary power systems.
  • Electronic Prototyping: Providing a versatile power solution for maker projects.
  • Input Voltage: DC 6~24V
  • Output Voltage: DC 5V ±1%
  • Max Output Current: 16A
  • Output Ripple Noise: <20mV (1~16A load)
  • Conversion Efficiency: >90% (input 12V, load 1~16A)
  • Static Current (EN floating): <2mA
  • Static Current (EN grounded): <3µA
  • Operating Temperature: -25℃ ~ +70℃
  • Output Short Circuit Protection: Yes
  • Over-Temperature Protection: 125°C
  • Dimensions: 30 x 26 x 8mm
  • DC-DC Buck Converter (6~24V to 5V/16A) × 1
  • Only 6 Left
