Beetle RP2350 Mini Dual-Core Development Board (ARM Cortex-M33 / RISC-V)
$4.90
SKU: DFR1188
A compact, high-performance development board with dual-core processing, 11 IOs, battery management, and supports C/C++, MicroPython, and Arduino.
The Beetle RP2350 is a coin-sized, high-performance development board powered by Raspberry Pi RP2350 microcontroller. Featuring dual-core processing (ARM Cortex-M33 & RISC-V), 520KB RAM, and 2MB Flash, it’s perfect for space-constrained applications like wearables, smart home devices, and industrial IoT. With built-in lithium battery management, 11 accessible IOs, and support for C/C++, MicroPython, and Arduino, it combines portability, efficiency, and ease of use—making it the ultimate solution for compact, power-efficient designs.
High-performance Raspberry Pi RP2350 Chip
The Beetle RP2350 is powered by the RP2350, a versatile microcontroller developed by Raspberry Pi. It features a unique dual-core and dual-architecture design, offering the flexibility to choose between an Arm Cortex-M33 core or a Hazard3 RISC-V core. Operating at a 150MHz main frequency, with 520KB of RAM and 2MB of Flash, it ensures fast data processing and smooth execution of complex tasks, making it suitable for high-speed computing applications.
Highly Integrated and Ultra-small Size
With a coin-sized footprint of 25 × 20.5mm, the Beetle RP2350 provides a high level of integration without sacrificing functionality. It includes 11 accessible IOs, allowing flexibility for various peripheral connections. Additionally, the board features built-in lithium battery charging management and voltage monitoring, ensuring uninterrupted operation by monitoring power levels and recharging when necessary.
Coin-sized development board - Beetle RP2350
Flexible Development Support
The Beetle RP2350 supports development with C/C++, MicroPython, and Arduino, offering flexibility across embedded prototyping and compact device applications.
As the RP2350 ecosystem continues to evolve, library compatibility and advanced peripheral support may vary depending on the selected framework and software version.
  • High-performance Raspberry Pi RP2350 chip
  • Dual-core dual-architecture design (switchable between Arm Cortex-M33 and Hazard3 RISC-V cores)
  • Ultra-compact integrated design
  • Built-in lithium battery charging management and voltage monitoring
  • Supports C/C++, MicroPython, and Arduino programming
  • 11 programmable I/O interfaces
  • Single-sided PCB layout with half-hole process for SMT production
  • DIY Retro Computers and Game Consoles
  • Programmable lighting control
  • Stage prop control
  • Core Frequency: 150MHz
  • Memory: 520KB RAM, 2MB Flash
  • Dimensions: 25×20.5mm (module size)
  • Operating Voltage: 3.3V
  • Input Voltage:
         Type-C Port: 5V DC
         VIN Pin: 5V DC
  • Operating Temperature: -10℃ to 60℃
  • Beetle RP2350 Mini Development Board x1
  • 10pin-2.54mm pitch pin header x2
    Certifications
    MACROPAD
    Projects MACROPAD
    Mukesh Sankhla
    Jun 05, 2026
    David. Feb 09, 2026
    Excellent value product
