Gravity: LoRaWAN Node Module (US915) – SX1262-Based, 4.5km Range for IoT & Agriculture
$9.90
SKU: DFR1115-915
Compact wireless communication module for outdoor IoT, supporting LoRa and LoRaWAN. Enables long-distance, low-power transmission, ideal for agriculture and industrial sensing.
This module is a compact, easy-to-integrate wireless communication solution tailored for long-distance, low-power outdoor IoT scenarios. Based on the SX1262 chip and LoRa modulation technology, it operates in the US915 frequency band (also applicable to EU868 in other versions) and supports both LoRa point-to-point and LoRaWAN networking. With an effective urban transmission range of up to 1.5 kilometers and 4.5 kilometers in open environments, it enables reliable, wide-area data transmission without the need for traditional wired infrastructure. Ideal for agriculture, environmental monitoring, and industrial sensing projects.
Dual Communication Modes: LoRa & LoRaWAN
Supports both LoRa point-to-point communication (one-to-one, one-to-many, many-to-one, and bridge transmission) and LoRaWAN networking (Class A and Class C). This dual-mode design offers flexible deployment options—whether for direct module-to-module communication or integration with cloud platforms like TTN or ChirpStack via LoRaWAN gateways.
Kilometer-Range Wireless Transmission
Designed for outdoor environments, the module delivers reliable long-distance performance: up to 1.5 km in urban settings and up to 4.5 km in open areas. This makes it suitable for use cases where Wi-Fi or 4G coverage is limited or too power-hungry.
Quick Integration and Low Learning Curve
Features built-in LoRa/LoRaWAN protocol stack—no need for low-level development. Supports Arduino IDE, Mind+, and MakeCode graphical programming, and offers I2C/UART interfaces compatible with popular platforms like micro:bit, Arduino, and ESP32. Enables seamless integration and rapid prototyping for IoT developers and educators alike.
DFRobot LoRaWAN Series
DFRobot LoRaWAN Series Products
DFRobot LoRaWAN product series is centered on "simplified development and efficient deployment", covering scenarios such as learning, development, testing, and deployment, and providing developers with comprehensive low-power wide-area network (LPWAN) solutions.
  • Gateway: Embedded local MQTT server (SIoT) eliminates the need for server setup; supports Node-RED graphical programming for rapid automation task construction.
  • Control Terminal: Multi-interface design (analog/digital input, RS485, relays) enables both data acquisition and device control; supports custom control rules and stable offline operation without network connectivity.
  • Development Board: Compatible with the Arduino ecosystem, providing pre-built libraries and sample code for a low-threshold getting started; integrated with a screen, buttons, and other peripherals for real-time debugging without external devices.
  • Node Module: Built-in LoRa/LoRaWAN protocol stack, supporting multi-platform graphical programming; features standard I2C/UART interfaces, compatible with mainstream controllers such as Micro:bit, Arduino, and ESP32
  • Video: Long-Range Private IoT with DFRobot LoRaWAN Gateway & Nodes: 4km Range, Local Server & Dashboard
  • Farm condition monitoring
  • Greenhouse temperature and humidity sensing
  • Beehive monitoring
  • Ecological area data collection
  • LoRaWAN-enabled weather stations
    Electrical & Interface
  • Operating Voltage: 3.3V to 5V DC
  • Communication Interfaces: UART and I2C
  • Connector Type: PH2.0-4P
  • Logic Level Compatibility: 3.3V / 5V
  • Mechanical
  • Board Dimensions: 42 × 62 mm (1.65 × 2.44 in)
  • Mounting Hole Diameter: 3.0 mm (0.12 in)
  • Mounting Hole Spacing: 35 mm (1.38 in)
  • Net Weight: 10 g (0.35 oz)
  • Wireless Communication (LoRa)
  • RF Chip: Semtech SX1262
  • Operating Frequency: 915 MHz
  • Supported Regions: North America and other regions using the US915 frequency band
  • Modulation: LoRa
  • Spreading Factor: SF7 to SF12
  • Max Transmit Power: +22 dBm
  • Receiver Sensitivity: -137 dBm (SF12 @ 125 kHz bandwidth)
  • Gravity: LoRaWAN Node Module (915MHz) ×1
  • PH2.0-4P connection cable ×1
    LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Blog LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Jan 16, 2025
    6 Applications of Lora Technology
    Blog 6 Applications of Lora Technology
    May 03, 2023
    Getting Started with LoRaWAN
    Blog Getting Started with LoRaWAN
    May 05, 2023
    LoRa vs LoRaWAN
    Blog LoRa vs LoRaWAN
    Apr 11, 2023
    LoRaWAN Gateway Software
    Blog LoRaWAN Gateway Software
    Aug 09, 2023
