This PH2.0-4P male-to-male cable provides a reliable and easy-to-use wiring solution for modular electronics and educational platforms such as Boson and UNIHIKER. With polarized 4-pin PH2.0 connectors on both ends, it ensures correct orientation, prevents reverse insertion, and simplifies wiring between sensors, modules, and expansion boards.
Its compact 10cm length is ideal for tight spaces and organized builds, making it a practical accessory for IoT projects, STEM kits, and rapid prototyping.
