PH2.0-4P Male-to-Male Jumper Cable - 10cm (10 Pack)
$5.90
SKU: FIT0914
This 10cm PH2.0-4P male-to-male cable ensures secure connections and prevents reverse insertion, perfect for modular electronics and educational platforms.
This PH2.0-4P male-to-male cable provides a reliable and easy-to-use wiring solution for modular electronics and educational platforms such as Boson and UNIHIKER. With polarized 4-pin PH2.0 connectors on both ends, it ensures correct orientation, prevents reverse insertion, and simplifies wiring between sensors, modules, and expansion boards.
Its compact 10cm length is ideal for tight spaces and organized builds, making it a practical accessory for IoT projects, STEM kits, and rapid prototyping.
  • 4-pin PH2.0 male connectors on both ends for secure, reversible-proof connections
  • Fully compatible with Boson modules and the UNIHIKER development board
  • Compact 10 cm (3.94 in) length for short-distance connections and clean layouts
  • Ideal for use in education kits, DIY electronics, and modular system wiring
  • Connector Type: PH2.0-4P (Male to Male)
  • Cable Length: 10 cm (3.94 in)
  • Quantity: 10 cables per pack
  • PH2.0-4P Male-to-Male Cable (10 cm) ×10
  • Only 1 Left
