LoRaWAN ESP32-S3 Dev Board with Display for IoT Prototyping & Smart Home
$18.50
SKU: DFR1195
  • $18.00 3+ items
  • $17.50 5+ items
  • $17.00 10+ items
It supports LoRa/LoRaWAN/Meshtastic protocols, is compatible with HomeAssistant, and is a wireless communication hardware with high usability.
Purchase this product and earn 185 reward points, which are tied to VIP membership program. Learn More >
The LoRaWAN ESP32-S3 Development Board is a professional hardware focusing on long-range wireless communication and convenient development. With comprehensive compatibility for LoRa, LoRaWAN, and Meshtastic protocols, integration capability with the HomeAssistant ecosystem, and user-friendly hardware function design, it provides an efficient solution for LoRa/LoRaWAN developers and smart home users.
Comprehensive Support for LoRa/LoRaWAN/Meshtastic Communication Protocols with Strong Communication Compatibility
The LoRaWAN ESP32-S3 Development Board supports LoRa one-to-one communication, LoRa one-to-many communication, as well as the standard LoRaWAN protocol and Meshtastic networking protocol. It enables flexible communication between development boards or integration into LoRaWAN networks. The board uses Arduino for programming and provides easy-to-use library files and sample code. There is no need to have in-depth knowledge of LoRa/LoRaWAN communication protocols to use it, which greatly lowers the entry barrier.
Support for Integration with HomeAssistant (ESPHome) to Expand Long-Range Communication Capabilities
The LoRaWAN ESP32-S3 Development Board can be integrated into HomeAssistant via ESPHome, serving as a "long-range communication expansion unit" for the system. It effectively breaks through the distance limitations of traditional wireless communication, enhances signal coverage and transmission stability in complex environments (such as multi-story buildings, large residences, and outdoor scenarios), and expands the deployment range of smart home devices.
Rich Functions and High Usability, Significantly Improving Testing Efficiency
The functional design of the LoRaWAN ESP32-S3 Development Board centers on "high efficiency and ease of use". Through high hardware integration, it significantly reduces test preparation time and device connection complexity:
  • Visual Operation and Data Viewing: It integrates a 0.96-inch LCD screen and physical buttons. Without relying on external devices, you can view key information such as device operation data and communication status in real time. At the same time, you can quickly switch display interfaces through the buttons, making the operation intuitive and convenient.
  • Portable Battery Life, Free from Power Constraints: A dedicated lithium battery interface is designed, and charging function is integrated to support external lithium battery power supply. Whether it is used for indoor desktop testing or outdoor mobile scenarios, it can get rid of the limitation of fixed power supply, making the application scenarios more flexible.
  • Easy-to-Use IO Interfaces for Effortless Sensor Connection: It is equipped with convenient IO interfaces, allowing direct connection to various sensor devices such as temperature and humidity sensors, light sensors, and human motion sensors without soldering. This solves the tedious wiring and soldering work during project setup and enables efficient construction of project prototypes.
  • Overview of ESP32-S3 LoRaWAN development board
    Figure: Overview of ESP32-S3 LoRaWAN development board
    DFRobot LoRaWAN Series
    DFRobot LoRaWAN Series Products
    DFRobot LoRaWAN product series is centered on "simplified development and efficient deployment", covering scenarios such as learning, development, testing, and deployment, and providing developers with comprehensive low-power wide-area network (LPWAN) solutions.
  • Gateway: Embedded local MQTT server (SIoT) eliminates the need for server setup; supports Node-RED graphical programming for rapid automation task construction.
  • Control Terminal: Multi-interface design (analog/digital input, RS485, relays) enables both data acquisition and device control; supports custom control rules and stable offline operation without network connectivity.
  • Development Board: Compatible with the Arduino ecosystem, providing pre-built libraries and sample code for a low-threshold getting started; integrated with a screen, buttons, and other peripherals for real-time debugging without external devices.
  • Node Module: Built-in LoRa/LoRaWAN protocol stack, supporting multi-platform graphical programming; features standard I2C/UART interfaces, compatible with mainstream controllers such as Micro:bit, Arduino, and ESP32
  • Video: Long-Range Private IoT with DFRobot LoRaWAN Gateway & Nodes: 4km Range, Local Server & Dashboard
  • Supports LoRa, LoRaWAN, and Meshtastic long-range communication protocols
  • Supports integration with HomeAssistant (ESPHome), enabling the HomeAssistant system to support long-range communication
  • Equipped with ESP32-S3 main controller, supporting Arduino and YAML programming
  • Rich functions and high usability, significantly improving testing efficiency
            Integrates a 0.96-inch screen and buttons for easy data viewing and display switching
            Integrates multiple sets of power supplies and I2C interfaces for easy sensor device connection
            Integrates a lithium battery interface and charging function for convenient portable use
  • LoRa/LoRaWAN Network Deployment and Debugging: View LoRaWAN network signals and communication status through the development board screen for testing, enabling rapid network setup and adjustment.
  • Smart Home Expansion for Large Residences/Villas: In multi-story villas or houses with cross-courtyards, it easily connects garden sensors, garage devices, and indoor control systems, solving the problem of signal interruption caused by wall barriers and realizing unified management of all household devices.
  • Outdoor Environmental Monitoring Scenarios: Equipped with sensors such as temperature and humidity sensors and PM2.5 sensors, it can be deployed on balconies, rooftops, or courtyards. It transmits data back to the HomeAssistant system in real time through long-range communication, and links with air conditioners and fresh air devices to automatically adjust the indoor environment.
  • Agricultural/Horticultural Remote Management: Placed in vegetable gardens, greenhouses, or orchards, it connects soil moisture and light sensors. Even indoors hundreds of meters away, you can grasp the crop growth environment in real time and trigger the irrigation system for automatic operation.
  • Meshtastic Chat Device: In outdoor scenarios with weak or no network signals, such as remote areas, mountain hiking, forest expeditions, and desert crossings, it uses the Meshtastic protocol to build a decentralized radio communication network, enabling real-time text message sending.
    Basic Parameters
  • Operating Voltage: 3.3V
  • Type-C Input Voltage: 5V DC
  • Maximum Charging Current: 300mA
  • Screen Size: 0.96 inches (160×80 pixels)
  • Operating Temperature: -10~60℃
  • Module Size: 73×45mm
  • LoRa Parameters
  • RF Chip: SX1262
  • Operating Frequency Band: 850~930MHz
  • Transmission Power: 16dBm (EU868) / 22dBm (US915)
  • Receiver Sensitivity: -137dBm / 125kHz SF=12
  • ESP32-S3 Parameters
  • Processor: Xtensa® dual-core 32-bit LX7 microprocessor
  • Clock Speed: 240MHz
  • SRAM: 512KB
  • ROM: 384KB
  • Flash: 4MB
  • Wireless Protocols: WiFi, Bluetooth 5
  • LoRaWAN ESP32-S3 Development Board x1
    DFRobot ESP32-S3 LoRaWAN & Gateway Review: Build a Private IoT Network
    Media DFRobot ESP32-S3 LoRaWAN & Gateway Review: Build a Private IoT Network
    androidpimp
    Mar 12, 2026
    LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Blog LPWAN in 2025: LTE-M vs NB-IoT vs LoRaWAN vs Sigfox
    Jan 16, 2025
    6 Applications of Lora Technology
    Blog 6 Applications of Lora Technology
    May 03, 2023
    Getting Started with LoRaWAN
    Blog Getting Started with LoRaWAN
    May 05, 2023
    LoRa vs LoRaWAN
    Blog LoRa vs LoRaWAN
    Apr 11, 2023
    LoRaWAN Gateway Software
    Blog LoRaWAN Gateway Software
    Aug 09, 2023
    Pauli.Hakala Jun 07, 2026
    Good product to start with
    Only 17 Left
