High-Speed 2500V Multi-Rate Industrial USB 2.0 Isolator (480Mbps)
$26.90
SKU: FIT1019
  • $26.00 3+ items
  • $26.50 5+ items
  • $25.00 10+ items
Protects USB ports from power interference and signal noise, with 2500V isolation and high-speed data transfer. Ideal for harsh environments and sensitive applications.
Purchase this product and earn 269 reward points, which are tied to VIP membership program. Learn More >
Shield sensitive USB ports from damaging external power interference and signal noise. This 2500V multi-rate industrial-grade USB isolator delivers robust protection for development boards, motherboards, and other critical equipment, ensuring reliable high-speed (480Mbps) data transfer in demanding environments.
Ultimate Electrical Protection
This module employs advanced magnetic isolation technology to create a complete electrical barrier. It effectively isolates ground loops between USB devices, safeguarding against damage from ground loop voltage, surges, induced lightning strikes, static electricity (ESD), and hot-swapping incidents. Expect significantly enhanced communication stability and extended equipment lifespan.
Seamless High-Speed Performance
Experience full USB 2.0 compatibility with driver-free operation. The isolator automatically adapts to Low Speed (1.5Mbps), Full Speed (12Mbps), and High Speed (480Mbps) communication rates, ensuring versatile connectivity for a wide range of devices without performance bottlenecks.
Industrial-Grade Reliability
Engineered for resilience, this USB isolator operates reliably in extreme conditions, from -40°C to 85°C. It's an ideal solution for high-voltage, high-interference environments such as power systems, inverters, and motor drives, as well as noise-sensitive applications like high-precision data acquisition and HIFI audio systems.
Plug-and-Play Simplicity
No external power supply is required for most applications (supports up to 1.5W output). The driver-free design ensures effortless integration with various operating systems, making setup quick and straightforward.
Figure: Dimensions of 2500V multi-rate industrial-grade USB isolator
Figure: Compatible Systems of 2500V multi-rate industrial-grade USB isolator
Usage Notes: The isolated output power is 1.5W. If connected devices require a working current greater than 300mA, an additional external power supply is recommended to ensure proper operation.
  • Protection in high-voltage, high-interference settings (e.g., power systems, inverters, motor drives).
  • Noise reduction in sensitive areas (e.g., high-precision USB data acquisition, HIFI audio systems).
  • Safeguarding USB interfaces on development boards and computer motherboards.
  • Compatibility: Standard USB 2.0, driver-free
  • Interface Speed: Auto-adapting:
         Low Speed: 1.5Mbps
         Full Speed: 12Mbps
         High Speed: 480Mbps
  • Transmission Modes: USB control, batch, interrupt, synchronous/asynchronous
  • USB Ports Protection: Independent ESD protection; isolated power and signals for upstream/downstream ports
  • Isolation Chip: ADUM3165
  • Chip Isolation Voltage: 2500V
  • Power Isolation Voltage: 1500V
  • Output Power: Max 1.5W (5V/300mA)
  • Operating Environment: -40°C to 85°C; 5% to 95% RH (Relative Humidity)
  • Dimensions: 50mm x 28mm x 20mm
  • Cable Length: 200mm
  • Weight: Approx. 40g
  • High-Speed 2500V Multi-Rate Industrial USB 2.0 Isolator
  • Only 12 Left
