RDK X5 Metal Heatsink Case
$11.00
SKU: FIT1025
The metal heatsink case provides durable protection and superior heat management for the AI board. It features precise cutouts for ports and easy installation.
Purchase this product and earn 110 reward points, which are tied to VIP membership program. Learn More >
The RDK X5 Metal Heatsink Case is an essential accessory engineered exclusively for the RDK X5 AI Board. Constructed from a durable, black anodized metal, this case provides both robust protection and superior passive thermal management. Its design ensures the RDK X5 maintains optimal performance and stability, even during computationally intensive tasks, by effectively dissipating heat from the main processor.
Precision cutouts grant full access to all ports and the antenna connector, ensuring seamless connectivity and plug-and-play functionality without compromising protection. The simple four-screw assembly makes installation and removal straightforward.
Optimized Thermal Performance
The entire metal enclosure functions as a large passive heatsink, significantly improving heat dissipation to prevent thermal throttling and ensure stable operation. A thermal silicone pad is included to guarantee efficient heat transfer from the CPU to the case.
Robust Protection
Safeguards the RDK X5 board from physical damage, dust, and accidental short-circuits in various development and deployment environments.
Unhindered Access & Connectivity
Features precision-engineered openings for all ports, including GPIO, USB, HDMI, and Ethernet, as well as a dedicated cutout for the antenna to maintain strong and stable wireless signal transmission.
Simple & Secure Installation
The case is easily and securely assembled with the four included screws, providing a snug and reliable fit for the RDK X5 board.
Product Display of RDK X5 and Metal Heatsink Case
Figure: Product Display of RDK X5 and Metal Heatsink Case
Installation of RDK X5 Metal Heatsink Case
Figure: Installation of RDK X5 Metal Heatsink Case
Usage & Safety Precautions
  • Designated Use: For exclusive use with the RDK X5 board.
  • Ventilation: Ensure operation in a well-ventilated area. Do not cover the case or obstruct airflow.
  • Electrical Safety: Keep away from liquids, moisture, and conductive surfaces to prevent short circuits.
  • Operating Temperature: Use under normal ambient conditions and avoid external heat sources.
  • Caution - Hot Surface: The case is a functional heatsink and will become hot during operation. Do not touch while powered on to prevent potential burns.
  • Material: Anodized Aluminum
  • Dimensions: 85×56×17mm
  • Weight: 78g
  • Color: Matte Black
  • Compatibility
          RDK X5 AI Board (4GB, 10Tops)
          RDK X5 AI Board (8GB, 10Tops)
  • RDK X5 Metal Heatsink Case ×1
  • M2.5*10 Cross-Head Screw ×5 (4 for assembly, 1 spare)
  • Thermal Conductive Silicone Pad ×1
  • Only 15 Left
