Arduino UNO Q Development Board (4GB LPDDR4, 32GB eMMC)
$59.00
SKU: DFR1256
The Arduino UNO Q is a hybrid development board combining a Qualcomm® Dragonwing™ MPU (Linux Debian) and an STM32 MCU. With 4GB RAM and 32GB eMMC, this "dual-brain" platform is optimized for containerized apps, AI vision, and robotics. It offers the processing power of a single-board computer with the real-time precision of the Arduino ecosystem.
Dual-Brain Hybrid Architecture
The UNO Q combines two distinct processing units. The Qualcomm® Dragonwing™ QRB2210 MPU operates as the primary computation engine, running a full Linux® Debian OS to manage networking, video processing, and high-level logic. Concurrently, the dedicated STM32U585 real-time MCU handles sensors, actuators, and precise timing. This separation of duties ensures that critical motor control loops remain uninterrupted by OS background tasks, delivering industrial-grade reliability.
Arduino UNO Q - Dual-Brain Hybrid Architecture
High-Performance AI & Vision
AI capabilities are readily accessible on this platform. With a quad-core 2.0 GHz CPU, Adreno GPU, and dual Image Signal Processors (ISPs), the UNO Q is engineered for on-device machine learning. The board supports video stream processing and AI models for tasks such as object detection and gesture recognition locally. The upgraded 4GB RAM facilitates smoother inference and enhanced performance when executing multiple models simultaneously.
Arduino UNO Q On-Device AI and Computer Vision
Seamless Development Ecosystem
The platform offers a unified workflow for diverse development needs. The Arduino App Lab and pre-installed Linux environment enable the creation of classic Arduino Sketches for the MCU, Python® scripts for the MPU, or a hybrid of both from a single interface. Development is further accelerated through pre-built AI examples, Docker and Docker Compose support, and access to a vast library of open-source software.
Arduino UNO Q Full Debian Linux Environment
Expanded Connectivity & Compatibility
Maintained within the classic UNO form factor, the UNO Q ensures compatibility with a wide range of existing Arduino shields. It also features a Qwiic connector for solder-free expansion with Modulino® nodes and third-party modules. With built-in Dual-band Wi-Fi® 5 (2.4/5 GHz), Bluetooth® 5.1, and USB-C video output, the board is fully equipped for modern IoT connectivity requirements.
Arduino UNO Q Seamless Integration with the Arduino Ecosystem
Video: Introducing Arduino UNO Q
  • Advanced Robotics & Autonomous Systems
  • Edge AI & Computer Vision
  • Interactive Art & Kiosks
    Microprocessor Unit (MPU) - Qualcomm Dragonwing™ QRB2210
  • CPU: Quad-core Arm® Cortex®-A53 @ 2.0 GHz
  • GPU: Adreno GPU 3D graphics accelerator
  • ISP: 2x ISP (Supports 13 MP + 13 MP or 25 MP) @ 30 fps
  • Operating System: Linux Debian OS with upstream support
  • RAM: 4GB LPDDR4
  • Storage: 32GB eMMC built-in (No SD card required)
  • User Interface: 4x User-controllable RGB LEDs
  • Microcontroller Unit (MCU) - STM32U585
  • Core: Arm® Cortex®-M33 @ up to 160 MHz
  • Memory: 2 MB Flash memory, 786 KB SRAM
  • Real-time OS: Arduino Core on Zephyr OS
  • Feedback: 8x13 Blue LED Matrix
  • Protocols: I2C, I3C, SPI, PWM, CAN, UART, PSSI, GPIO, JTAG, ADC
  • Connectivity & Interface
  • Wi-Fi: Wi-Fi® 5 (2.4/5 GHz)
  • Bluetooth: Bluetooth® 5.1
  • USB: 1x USB-C® port (Supports Host/Device switching, Power Delivery, Video Output)
  • Video Output: Supported via USB-C or MIPI DSI pins on JMEDIA header
  • Expansion:
          Classic UNO Headers
          High-speed headers (Vision, Audio, Display)
          1x Qwiic connector (3.3V I2C)
  • Power & Dimensions
  • Power Supply: 5 VDC max @ 3A via USB-C connector
  • Input Voltage (VIN): 5 VDC
  • Dimensions: 68.85 mm x 53.34 mm (Standard UNO form factor)
  • Arduino UNO Q 4GB Development Board x 1
    AI-driven Web-based Ancillary Lab Assistant | UNO Q & Gemini
    Projects AI-driven Web-based Ancillary Lab Assistant | UNO Q & Gemini
    Kutluhan Aktar
    Jun 05, 2026
