2208 3-Phase Brushless DC Motor (12V 1800RPM, 300g.cm)
$16.90
SKU: FIT1035
  • $16.50 3+ items
  • $16.00 5+ items
  • $15.50 10+ items
Ditch the jitter! This 12V 2208 brushless motor has an integrated AS5600 encoder for silky-smooth FOC control. Perfect for camera gimbals, robotic joints, or learning FOC with Arduino.
Purchase this product and earn 169 reward points, which are tied to VIP membership program. Learn More >
This 2208 three-phase brushless DC motor is a compact, high-performance solution that integrates a high-precision AS5600 magnetic encoder. Operating at a rated 12V, this FOC-ready motor delivers 300g.cm of torque and provides 12-bit (0.087° accuracy) positional feedback. It is engineered specifically for applications requiring advanced motor control, particularly Field-Oriented Control (FOC). This capability allows for precise management of the motor's magnetic field, resulting in exceptionally smooth torque, low operational noise, and high efficiency. This integrated design is ideal for sophisticated projects such as camera gimbals, balancing robots, and platforms for FOC algorithm development.
Integrated High-Precision Magnetic Encoder
At the core of this BLDC motor's capability is the built-in AS5600 magnetic encoder. This component provides high-resolution 12-bit positional feedback, achieving an accuracy of up to 0.087 degrees. This precise, real-time data is essential for implementing sophisticated closed-loop control systems. The encoder offers flexible connectivity through I2C, PWM, and analog outputs, ensuring compatibility with a wide range of microcontrollers.
Optimized for Field-Oriented Control (FOC)
This motor and encoder combination is perfectly suited for Field-Oriented Control (FOC), one of the most effective methods for controlling BLDC motors. By enabling FOC, this 2208 brushless motor can deliver smooth, ripple-free torque and operate with minimal noise and vibration. This contrasts sharply with traditional control methods, offering superior performance and efficiency for sensitive applications.
Quality Construction and Compact Design
Constructed for durability and performance, the motor features a precision CNC-machined housing, a strong NdFeB magnetic outer rotor, and a practical hollow-shaft design. The stator windings use oxygen-free copper, and the assembly process ensures excellent rotor dynamic balancing. This meticulous construction guarantees stable, reliable operation within a compact form factor that is easy to embed in various projects.
Broad Compatibility for Rapid Development
Designed for seamless integration, this 2208 BLDC motor is fully compatible with popular development platforms including Arduino, ESP32, and Raspberry Pi. When paired with the SimpleFOC open-source library and a suitable driver, such as the SimpleFOC Mini (DRI0058), developers can rapidly implement and experiment with advanced FOC algorithms, significantly shortening the development cycle.
Note: The motor UVW connection wires come in two colors: three-color and black. The motor windings are in a star configuration, with three-phase symmetry; there is no specific order requirement, and it does not affect usage.
  • Camera Stabilizers: Building ultra-smooth 2-axis or 3-axis camera gimbals.
  • Robotic Joints: Prototyping small, precise robotic arms and manipulators.
  • Balancing Robots: Creating self-balancing vehicles requiring high-speed feedback.
  • Education & Research: A perfect platform for learning and developing FOC algorithms.
  • Precision Automation: Driving small mechanisms that require quiet, smooth motion.
    Motor Electrical Parameters
  • Applicable Voltage: DC 7.4-16V
  • Rated Voltage: 12V
  • Rated Current: 0.8A
  • Maximum Current: 4.5A
  • Rated Power: 14W
  • Rated Speed: 1800 @ 12V
  • Torque: Approximately 300g.cm/0.03Nm
  • Number of Slots and Poles: 12N/14P
  • Number of Pole Pairs: 7
  • Winding Resistance: 21.2Ω
  • KV Value: 110KV
  • Phase Inductance: 5.3mH
  • Winding Configuration: Star Connection
  • Motor Mechanical Dimensions
  • Single Motor Size: 27.5x28mm
  • Winding Turns: 100T/Wire Diameter 0.14mm
  • Operating Temperature: 0-60°C
  • Encoder Parameters
  • Operating Voltage: 3.3V
  • Chip Model: AS5600
  • Resolution: 12-bit
  • Accuracy: 0.087°
  • Output Method: I2C, PWM, Analog Output (Default: I2C; PGO pin grounded for PWM/analog output)
  • Interface: GH1.25-4Pin
  • 2208 three-phase brushless DC motor (with encoder) x1
  • MX1.25-4P to DuPont cable x1
  • 3-pin motor cable x1
  • Out Of Stock
