4G GNSS-RTK High Precision Positioning Kit (EMEA & Thailand, GPS / GLONASS / Galileo / BDS / QZSS)
$119.00
SKU: KIT0212
A GNSS-RTK positioning kit (4G Version for EMEA & Thailand). Achieves 5cm + 1ppm accuracy by receiving RTCM correction data via 4G (Ntrip) from a CORS service. Supports GPS, GLONASS, Galileo, BDS, QZSS (L1/L5 bands). Outputs data via I2C/UART.
Purchase this product and earn 1190 reward points, which are tied to VIP membership program. Learn More >
GNSS-RTK High Precision Positioning Kit (4G Version) is a centimeter‑level positioning solution designed for robotics navigation, asset tracking, and geospatial data collection. By leveraging Network RTK technology, this high‑accuracy GNSS positioning system connects to a CORS network through an onboard 4G module to receive RTCM correction data via the Ntrip protocol, removing the need for a traditional local base station. Multi‑constellation and multi‑band satellite reception enables reliable performance with convergence times under 10 seconds. A flexible Gravity interface supporting I2C and UART simplifies integration with development platforms such as Arduino, ESP32, and Raspberry Pi.
Positioning Flowchart of GNSS-RTK positioning kit
Figure: Positioning Flowchart
Wide-Area Network RTK Coverage
Unlike traditional RTK systems limited by short‑range radio communication, this network‑based GNSS positioning module accesses correction data through a 4G connection to an existing CORS infrastructure. Such architecture expands operational coverage to approximately 15–20km while maintaining consistent centimeter‑level positioning accuracy. Removal of the dedicated base station reduces deployment complexity and hardware costs while enabling high‑precision positioning across a much larger service area, provided that CORS service coverage and a stable 4G signal are available.
Robust Multi‑Constellation & Multi‑Band Reception
High reliability and stable positioning performance are achieved through simultaneous tracking of multiple satellite constellations, including GPS, GLONASS, Galileo, BDS, and QZSS. Multi‑frequency reception across bands such as GPS L1/L5, Galileo E1/E5a, and BDS B1I/B2a significantly reduces ionospheric errors and multipath interference. This advanced satellite tracking capability allows the RTK navigation module to maintain strong signal availability and precise location locking even in complex outdoor environments where satellite visibility may fluctuate.
Simplified Deployment and Integration
Deployment becomes significantly easier compared with conventional RTK base‑rover configurations. Operation only requires inserting a 4G SIM card and configuring the module with valid CORS credentials, avoiding the logistical burden of installing and maintaining a base station. The Gravity interface provides selectable I2C and UART communication, allowing seamless connection with common microcontrollers and single‑board computers. Such flexible hardware compatibility enables rapid integration into robotics platforms, precision tracking systems, and outdoor sensing projects.
Wiring Diagram of GNSS-RTK positioning kit
Figure: Wiring Diagram of GNSS-RTK positioning kit
Differences Between Traditional RTK and Network RTK Positioning
Figure: Differences Between Traditional RTK and Network RTK Positioning
Application Summary
This high‑precision GNSS navigation kit provides an efficient positioning solution for outdoor robotics, autonomous vehicles, and geospatial measurement tasks. Network‑based RTK correction combined with multi‑band satellite tracking enables stable centimeter‑level positioning across wide areas. Reliable communication interfaces and simplified setup make this precision navigation module well suited for robotics research, fleet tracking systems, agricultural automation, and advanced positioning experiments.
  • Network RTK positioning using 4G connectivity to access CORS correction services
  • Centimeter‑level RTK accuracy up to 5 cm + 1 ppm
  • Operational coverage up to 15–20 km depending on CORS network availability
  • Supports multi‑constellation satellite systems: GPS, GLONASS, Galileo, BDS, and QZSS
  • Multi‑band reception including L1/L5, E1/E5a, and B1I/B2a
  • Fast RTK convergence time under 10 seconds
  • Gravity interface with selectable I2C and UART communication
  • Compatible with popular microcontroller platforms and single‑board computers
  • Eliminates the need for a local RTK base station
  • Autonomous rover navigation and outdoor robotics positioning
  • High‑precision asset and vehicle tracking systems
  • Geospatial trajectory recording and data logging
  • Field mapping, environmental monitoring, and survey experiments
  • Precision agriculture and autonomous machine guidance
  • Power Interface: Gravity interface, 3.3~5V
  • Type-C: For 4G module power (requires separate power supply)
  • Output Signal: I2C / UART
  • Antenna Interface: SMA
  • Reception Bands:
    GPS/QZSS: L1 C/A, L5
    GLONASS: L1
    Galileo: E1, E5a
    BDS (BeiDou): B1l, B2a
  • Default Constellations: GPS + GLONASS + Galileo + BDS + QZSS
  • Concurrent Tracking Constellations: 4+ QGNSS
  • SBAS: WAAS, EGNOS, MSAS, GAGAN
  • Function: RTK
  • Horizontal Positioning Accuracy:
    Autonomous: 1 m
    RTK: 5 cm + 1 ppm
  • Velocity Accuracy: 0.03 m/s
  • 1PPS Accuracy: 20 ns
  • RTK Convergence Time: < 10 s
  • Sensitivity:
    Acquisition: -145 dBm
    Tracking: -165 dBm
    Reacquisition: -157 dBm
  • Dynamic Performance:
    Max Altitude: 10000 m
    Max Velocity: 500 m/s
    Max Acceleration: 4 g
  • Navigation Update Rate (RTK): 1 Hz
  • Raw Data Output Rate (GNSS): 1 Hz
  • Protocol: NMEA 0183 / RTCM 3.x
  • Weight: about 380g
  • Supported Countries/Regions: EMEA & Thailand
  • RTK Mobile ×1
  • GNSS Antenna ×1
  • 4G/LTE Right-Angle Rubber Duck Antenna (Internal Pin, 3dBi) ×1
  • Flathead Screwdriver ×1
  • Plug-in Terminal Block DB2EK-3.81-2P-GN-S (Female) ×1
  • PH2.0-4P Connection Cable (30cm) ×1
