LoRaWAN Control Terminal (915MHz) serves as a compact Industrial IoT control node designed to connect field sensors, actuators, and remote monitoring platforms through long‑range wireless communication. Operating within the 902–928MHz band, this DIN‑rail industrial controller integrates data acquisition, logic execution, and device control in a single hardware unit. The multi‑interface architecture enables seamless integration with RS485 Modbus sensors, analog transmitters, and digital signals, making the system well suited for distributed telemetry projects. By combining reliable LoRaWAN connectivity with local automation capability, this wireless RTU simplifies deployment across smart agriculture installations, industrial monitoring networks, and building automation systems where wired communication is impractical.
Reliable Long‑Range LoRaWAN Communication
Built on the standard LoRaWAN protocol stack, the industrial wireless terminal supports stable communication with both private LoRaWAN gateways and public network infrastructure. Operation in the 915MHz frequency band provides strong signal penetration and kilometer‑scale coverage, enabling dependable data transmission from geographically dispersed assets such as agricultural parks, remote environmental stations, and large factory campuses. This LPWAN connectivity eliminates the complexity of long cable runs or unstable Wi‑Fi links, providing an efficient communication backbone for distributed Industrial IoT sensing and control deployments.
Hybrid Interface for Data Acquisition and Control
This industrial control module integrates multiple input and output interfaces to support both monitoring and actuation tasks within a single system node. An RS485 interface supports Modbus RTU sensors, while a 0–10V analog input allows connection to industrial transmitters. Two optocoupler‑isolated digital inputs accept external signals ranging from 5–24V. For control applications, a relay output rated at 24VDC 3A or 220VAC 3A enables direct switching of pumps, valves, alarms, and lighting systems. The combination of acquisition and control interfaces allows complex field automation without requiring additional controllers.
Edge Logic Execution and Offline Operation
An embedded rule engine allows local automation without constant cloud connectivity. Logical conditions can be configured through a visual interface to create automatic responses such as triggering irrigation when soil moisture drops below a threshold or activating alarms based on sensor readings. Even if LoRaWAN connectivity becomes temporarily unavailable, the industrial edge controller continues executing preset control logic. This autonomous operation ensures continuous equipment management and system stability in remote monitoring scenarios where network reliability may fluctuate.
Compatible with Industrial RS485 Sensor Ecosystems
The LoRaWAN industrial terminal integrates seamlessly with a wide range of Modbus RTU sensors, enabling flexible system expansion across diverse monitoring environments. Compatible devices include soil monitoring probes measuring temperature, moisture, EC, pH, and nutrient content, as well as water quality sensors such as fluorescence dissolved oxygen meters. Weather monitoring equipment—including ultrasonic multi‑parameter weather stations—and ambient light sensors for solar radiation, PAR, UV, and illumination can also be connected. Configuration parameters such as baud rate and device address vary by sensor model; detailed Modbus register maps are available in the Peripheral Device Recommendations.
DFRobot LoRaWAN Series
Figure: DFRobot LoRaWAN Series Products
DFRobot LoRaWAN product series focuses on simplified development and efficient deployment, covering learning, prototyping, testing, and real‑world IoT deployments. The ecosystem provides developers with a complete LPWAN solution for building scalable long‑range wireless systems.
Video: Long-Range Private IoT with DFRobot LoRaWAN Gateway & Nodes: 4km Range, Local Server & Dashboard
Basic Parameters
Communication Interface
Wireless Parameters
