URM Ultrasonic Mounting Bracket
$3.00
SKU: FIT0006
The mounting bracket is designed for URM ultrasonic sensors, featuring a 14mm pitch, 5g weight, and dimensions of 60x20x30mm. Includes bracket, 2 rubber rings, and 2 screws.
Purchase this product and earn 30 reward points, which are tied to VIP membership program. Learn More >
URM Ultrasonic Sensor Mounting Bracket provides a compact mechanical solution for securing ultrasonic distance modules in robotics and embedded sensing projects. Designed specifically for the URM ultrasonic sensor series, this lightweight mounting accessory stabilizes the sensor body while maintaining the correct forward-facing orientation required for accurate distance measurement. Full compatibility with URM37 and URM04 makes this ultrasonic sensor holder a convenient integration component for mobile robots, obstacle detection platforms, and experimental prototyping systems requiring secure sensor positioning.
Precision Alignment for Ultrasonic Distance Sensors
This ultrasonic sensor mounting frame maintains stable positioning for URM series ranging modules, helping preserve measurement consistency during operation. Proper alignment of the transmitter and receiver improves detection accuracy in robotics navigation, object avoidance, and environmental sensing systems. The rigid structure minimizes vibration and unwanted movement that may occur when sensors are mounted directly to chassis surfaces. Consistent spacing and balanced support allow ultrasonic detection hardware such as URM37 and URM04 to maintain reliable signal transmission and echo reception in dynamic mechanical environments.
Compact Structure with Simple Installation
This mechanical bracket integrates a straightforward mounting layout that simplifies installation onto robot frames, mobile platforms, and experimental assemblies. A 14 mm mounting pitch accommodates compatible ultrasonic modules while the included rubber rings help stabilize the sensor body and reduce vibration during movement. Lightweight construction at only 5 g ensures minimal load on robotic structures or servo mounts. Compact dimensions also allow integration into space‑constrained designs such as small mobile robots, autonomous vehicles, and embedded sensing platforms where efficient component placement is essential.
Reliable sensor mounting hardware improves overall system stability in robotics and prototyping environments. This URM-compatible mounting accessory supports clean installation of ultrasonic ranging modules in obstacle‑avoidance robots, smart vehicles, and interactive electronic systems. By maintaining accurate sensor orientation and mechanical stability, this bracket helps ultrasonic sensing systems deliver consistent distance measurements during experimentation, educational development, and embedded robotics applications.
  • Designed for URM ultrasonic sensor series
  • Compatible with URM37 and URM04 ultrasonic sensors
  • Maintains stable sensor alignment for accurate ranging
  • Compact and lightweight structure for robotics integration
  • Includes rubber rings for vibration reduction and secure mounting
  • Simple mechanical installation for prototyping and robotics platforms
  • Ultrasonic sensor mounting for mobile robots
  • Obstacle avoidance and distance detection systems
  • Autonomous vehicle and smart car projects
  • Educational robotics experiments
  • Prototyping platforms requiring stable ultrasonic sensor positioning
  • Mounting Pitch: 14mm(0.55 in)
  • Weight: 5g
  • Size: 60mm x 20mm x 30mm (2.4in x 0.8in x 1.2in)
  • Bracket x1
  • Rubber Ring x2
  • Screw x2
  • Review
    TAKAO.SAKAMOTO May 31, 2025
    Just fitting and easy install
