Gravity: Joystick Module for Arduino / ESP32 / micro:bit / Raspberry Pi
$5.30
SKU: DFR0061
  • $5.10 2+ items
  • $4.90 5+ items
  • $4.50 10+ items
A joystick module for controlling robots via analog and digital inputs, featuring auto-return, compact design, and compatibility with Arduino, Raspberry Pi, and more.
Purchase this product and earn 53 reward points, which are tied to VIP membership program. Learn More >
Many robot projects need a joystick controller. The upgraded Arduino analog and digital joystick module provides a simple and user-friendly solution. By connecting to two analog inputs, the robot can be controlled by X, Y axes according to your commands. It also features a push button switch that connects to a digital pin. This joystick module is an ideal choice for controlling small robots, arm movements, or controlling remote devices. The spring auto-return feature makes it easy to operate and has a stable performance that is suitable for extended use. With a compact design and easy-to-mount layout, this Arduino joystick module is perfect for a variety of robotic and DIY projects.
Wiring Diagram of Joystick Module and Arduino UNO
Figure: Wiring Diagram of Joystick Module and Arduino UNO
This joystick module is compatible with common controllers such as Arduino, micro:bit, ESP32, Raspberry Pi, and Raspberry Pi Pico. It can be easily connected to Arduino by IO Expansion Shield with supplied cables.
If you are a beginner, it is recommended to purchase an Arduino kit with tutorials, such as the Gravity: Intermediate Kit for Arduino and the Gravity: Science Data Acquisition Module Kit for Experiments Education. These kits come with comprehensive tutorials and all the components necessary to complete a variety of projects, allowing you to gradually learn and build upon your knowledge and skills.
  • Standard assembling structure (two 3mm holes with multiple of 5cm as interval)
  • Concise icons describing sensor functions
  • High-quality connectors with good durability against repeated plugging and unplugging
  • Immersion gold surface
  • Supply Voltage: 3.3V to 5V
  • Compatible Controllers:
  • Arduino Series
  • ESP32 Series
  • Raspberry Pi Pico
  • Raspberry Pi (Requires ADC extension)
  • micro:bit
  • UNIHIKER
  • Interface: Analog x2,Digital x1
  • Size:39 x 35 x 30mm
  • Joystick Module V2 x1
kyle.benson Oct 12, 2023
Very nice joystick. Works well!
kyle.benson May 18, 2023
Very fast shipping. Thank you!
Only 16 Left
