Many robot projects need a joystick controller. The upgraded Arduino analog and digital joystick module provides a simple and user-friendly solution. By connecting to two analog inputs, the robot can be controlled by X, Y axes according to your commands. It also features a push button switch that connects to a digital pin. This joystick module is an ideal choice for controlling small robots, arm movements, or controlling remote devices. The spring auto-return feature makes it easy to operate and has a stable performance that is suitable for extended use. With a compact design and easy-to-mount layout, this Arduino joystick module is perfect for a variety of robotic and DIY projects.
Figure: Wiring Diagram of Joystick Module and Arduino UNO
This joystick module is compatible with common controllers such as Arduino, micro:bit, ESP32, Raspberry Pi, and Raspberry Pi Pico. It can be easily connected to Arduino by IO Expansion Shield with supplied cables.
If you are a beginner, it is recommended to purchase an Arduino kit with tutorials, such as the Gravity: Intermediate Kit for Arduino and the Gravity: Science Data Acquisition Module Kit for Experiments Education. These kits come with comprehensive tutorials and all the components necessary to complete a variety of projects, allowing you to gradually learn and build upon your knowledge and skills.
Oct 12, 2023
Very nice joystick. Works well!
May 18, 2023
Very fast shipping. Thank you!
