Light Disc with 7 SMD RGB LED
$2.90
SKU: DFR0106
This 5V light disc features 7 bright SMD RGB LEDs, ideal for Arduino projects. It includes a built-in resistor and allows color control via RGB pins.
Light Disc with 7 SMD RGB LED is a compact circular lighting module designed for vivid multicolor illumination in embedded electronics and creative lighting builds. Seven surface‑mount RGB emitters are arranged on a single board to produce smooth blended color effects that exceed the visual uniformity of a single RGB LED package. Operating from a 5V supply, this RGB lighting module integrates current‑limiting resistors and exposes independent red, green, and blue control pins for flexible brightness and color control. Such a multicolor LED board provides a simple path for interactive lighting in Arduino projects, decorative electronics, and experimental lighting prototypes.
Seven‑LED RGB Array for Vivid Color Blending
This circular RGB LED module integrates seven SMD RGB emitters on a single board, producing bright and evenly distributed illumination. Compared with a traditional single RGB diode, the multi‑LED layout generates smoother color mixing and greater visual coverage. A luminous intensity of up to 6000 mcd delivers strong brightness suitable for ambient lighting or visual indicators. Such a compact lighting disc functions effectively as a miniature color panel for creative electronics, decorative enclosures, or visual feedback systems within interactive devices.
PWM‑Controlled Full‑Spectrum Lighting
Independent RGB control pins allow flexible color generation through pulse‑width modulation. By adjusting duty cycles across the red, green, and blue channels, this programmable LED lighting board can create a wide spectrum of colors and brightness levels. Such a configuration enables dynamic lighting effects including gradients, reactive lighting, and visual status indicators. The RGB control interface also makes the multicolor LED unit well suited for embedded systems, interactive installations, and sensor‑driven lighting environments.
Direct 5V Compatibility with Integrated Resistors
Built‑in resistors simplify electrical integration and ensure stable operation with common microcontroller platforms. A standard 5V operating voltage allows direct connection to digital outputs without additional external components. Such integration reduces wiring complexity while improving reliability in rapid prototyping environments. This compact illumination board therefore works smoothly in USB‑powered builds, development boards, and experimental circuits where quick setup and dependable LED operation remain important.
The image above is using this light disc with a glass cover, with proper sensor, you can make your own mood light or music light
Such an RGB lighting disc supports numerous creative electronics applications ranging from ambient mood lighting and music‑responsive lamps to interactive art installations. Combined with sensors and microcontrollers, the circular LED module enables responsive color effects driven by sound, motion, or environmental data. Compact dimensions and straightforward wiring make the lighting board a practical component for decorative electronics, experimental lighting systems, and educational prototyping projects.
  • Seven SMD RGB LEDs arranged for uniform color mixing
  • PWM control via independent red, green, and blue pins
  • High brightness output up to 6000 mcd
  • Integrated resistors for direct 5V operation
  • Suitable for microcontroller lighting and decorative electronics
  • Mood lighting and decorative electronics
  • Music‑responsive light systems
  • Interactive lighting installations
  • Educational electronics projects
  • Visual indicators in embedded systems
    Basic Parameters
  • Power Supply: 5V
  • 7 SMD RGB LED
  • 6000 mcd
  • Light Disc with 7 SMD RGB LED x1
