2WD miniQ Robot Chassis
$25.00
SKU: ROB0049
2WD miniQ robotic platform is compact, easy to assemble, ideal for indoor use, maze competitions, and educational projects. Requires only 8 screws and sample codes are available.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
MiniQ 2WD Robot Chassis provides a compact robotic development platform designed for classroom learning, maker experimentation, and rapid prototyping. This circular two‑wheel drive robot base combines a lightweight structure with high‑speed metal gear motors, enabling agile movement across desktops and indoor environments. The small robotics platform supports rapid assembly using only a few screws while offering convenient mounting holes for sensors, controllers, and custom enclosures. Compatibility with popular development boards such as Arduino expands the chassis into a flexible robotics foundation for motion control, autonomous navigation experiments, and beginner robotics education.
Compact High‑Speed Mobility Platform
This two‑wheel drive robotic chassis integrates powerful metal gear motors that deliver fast and responsive movement despite the platform’s small footprint. A circular body layout improves maneuverability by reducing edge collisions when navigating obstacles, which benefits maze challenges and indoor robotics demonstrations. Lightweight construction also enables testing on desks or limited workspace environments. Combined with efficient gear reduction, the mobile robot base achieves a balanced combination of torque and speed suitable for educational robotics, rapid control experiments, and mobile sensor testing platforms.
Flexible Controller Integration
This mini mobile robotics base supports multiple robot control solutions. Popular options include the Romeo robot controller family, such as Romeo V2- an Arduino Robot Board (Arduino Leonardo) with Motor Driver and Romeo BLE (Arduino Robot Control Board with Bluetooth 4.0). Standard development boards paired with a motor shield also function effectively with the drivetrain system. Such flexibility allows robotics learners and engineers to build wireless robots, autonomous vehicles, or programmable mobile experiments using familiar development ecosystems.
miniQ with Romeo
miniQ with Romeo
MiniQ with Motor Shield, DFRduino and expansion shield.
MiniQ 2WD Robot Chassis Quick Assembly Guide Video
Convenient mounting holes across the round chassis simplify installation of sensors, control boards, and experimental hardware. Such expandability transforms the small robot platform into a practical base for maze‑solving robots, obstacle‑avoidance demonstrations, and educational robotics labs. Fast assembly, modular mounting options, and reliable drivetrain components make this compact robotic chassis suitable for robotics beginners, makers, and classroom engineering projects.
  • Compact circular 2WD robotic chassis designed for indoor robotics projects
  • High‑speed metal gear motors provide responsive movement
  • Lightweight structure suitable for desktop testing and prototyping
  • Multiple mounting holes support sensors, controllers, and custom enclosures
  • Compatible with Romeo robot controllers and motor driver shields
  • Quick assembly structure requiring only a small number of screws
  • Educational robotics platforms
  • Maze solving robots
  • Autonomous navigation experiments
  • Obstacle avoidance robot projects
  • STEM robotics courses and workshops
  • Mobile sensor testing platforms
    Chassis Specification
  • Chassis Diameter:122mm (4.8'')
  • Ground Clearance: 15mm (0.6'')
  • Wheel Diameter:42mm (1.65'')
  • Motor Specification
  • 13000 rpm @ No load
  • 50:1 Gear ratio
  • 260 rpm @ 6V
  • 40mA @ 6V
  • 360mA stall current @ 6V
  • 10 oz inches torque @ 6V
  • Micro Metal Gear Motor with Connector (75:1) x2
  • Rubber Wheels x2
  • Universal ball caster Wheels x2
  • MiniQ 2WD Chassis x1
  • Motor brackets x2
  • Screws x1 set
    WW2 Tank Laser Tag Sherman & Panther
    Projects WW2 Tank Laser Tag Sherman & Panther
    RiverTrue
    Mar 02, 2022
