2WD miniQ Robot Chassis
$25.00 $34.00
SKU: ROB0049
2WD miniQ robotic platform is compact, easy to assemble, ideal for indoor use, maze competitions, and educational projects. Requires only 8 screws and sample codes are available.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
2WD miniQ robotic platform is especially designed for students and hobbyists. It's versatile and small, suitable for most indoors applications. It features high quality and powerful metal gear motors which make it a speedy robot. It is ideal for maze competition and educational courses, and is very easy to assemble, check out our assembly video below. Only requires 8 screws to get the job done and you can use our sample codes on our Wiki pages.
If you are planning to get started building a robot, as a proof of concept, its small body and light weight makes it a great choice. This robot can easily be used and tested on a desk or small area, easily assembled and expanded. An extra set of stand off and screws might come handy. It's round shape helps when moving around objects, avoiding obstruction. The platform has convenient drillings that helps placing sensors or other screwable parts like custom designed casing.
To drive this robot, you may need the Romeo (Romeo V2- an Arduino Robot Board (Arduino Leonardo) with Motor Driver), the Romeo BLE (Arduino Robot Control Board with Bluetooth 4.0), or standard arduino with motor shield
miniQ with Romeo
MiniQ with Motor Shield, DFRduino and expansion shield.
MiniQ 2WD Robot Chassis Quick Assembly Guide Video
Chassis Specification
  • Chassis Diameter:122mm (4.8'')
  • Ground Clearance: 15mm (0.6'')
  • Wheel Diameter:42mm (1.65'')
Motor Specification
  • 13000 rpm @ No load
  • 50:1 Gear ratio
  • 260 rpm @ 6V
  • 40mA @ 6V
  • 360mA stall current @ 6V
  • 10 oz inches torque @ 6V
WW2 Tank Laser Tag Sherman & Panther
Projects WW2 Tank Laser Tag Sherman & Panther
RiverTrue
Mar 02, 2022
