3-Wire LED Module 8 Digital (Arduino Compatible)
$8.00
SKU: DFR0090
An 8-bit serial LED display with a flicker-free feature, red LEDs, SPI interface, and a 3-wire connection for linking multiple modules. Size: 122x20x12mm.
Purchase this product and earn 80 reward points, which are tied to VIP membership program. Learn More >
8 Digital Bits Serial LED Display is a compact numeric display module designed for embedded systems, instrumentation panels, and interactive electronics. The eight‑digit LED indicator integrates a simple serial communication design, enabling clear numeric output with minimal wiring. This LED display board supports stable 5V operation and uses a streamlined three‑wire communication structure that reduces microcontroller pin usage. The digital LED module also works smoothly with common development platforms such as Arduino, making the numeric display unit suitable for rapid prototyping, maker projects, and educational electronics setups that require clear multi‑digit data visualization.
Flicker‑Free Multi‑Digit LED Visualization
The eight‑digit LED indicator provides a stable and flicker‑free display output, ensuring numbers remain clearly visible during continuous updates. This serial numeric display module maintains consistent brightness across all digits, improving readability for counters, timers, sensor readouts, and measurement systems. The red LED display format enhances visibility in both indoor electronics labs and embedded control panels. Such stable visual output makes this digital display board well suited for real‑time monitoring interfaces where rapidly changing numerical data must remain easy to read.
Efficient 3‑Wire Serial Communication
The serial LED display board adopts a simplified 3‑wire communication interface, minimizing required I/O resources on the controller side. This architecture allows multiple numeric display modules to be cascaded together, enabling extended digit capacity without complex wiring. The three‑wire LED driver interface reduces hardware complexity while maintaining reliable data transmission. Such a streamlined connection approach makes the multi‑digit display unit practical for compact embedded systems, robotics status panels, and microcontroller‑driven monitoring equipment where available pins are limited.
Plug‑and‑Play Integration with Expansion Shields
Convenient hardware integration becomes possible when paired with the interface shield, enabling quick connection and simplified project assembly. This LED display module benefits from standardized connectors that reduce wiring errors and accelerate development cycles. The plug‑and‑play numeric display board therefore fits well into educational electronics platforms, rapid prototyping environments, and modular hardware ecosystems where reliable connections and quick deployment are essential.
This multi‑digit LED display module provides a practical visual output interface for embedded electronics. Typical implementations include digital clocks, scoreboards, sensor readout panels, and robotic status indicators. By combining a flicker‑free display, simple serial communication, and expandable module chaining, this numeric LED display board offers a reliable solution for projects requiring clear multi‑digit data presentation.
  • 8‑digit red LED numeric display
  • Flicker‑free visual output for clear data presentation
  • 3‑wire serial communication interface
  • Supports cascading multiple modules for extended digits
  • Compatible with common microcontroller platforms
  • Works with expansion shields for simplified connection
  • Digital clocks and timers
  • Electronic scoreboards
  • Sensor data readout displays
  • Embedded system status indicators
  • Educational electronics projects
  • Robotics control panels
  • Power Supply: 5V
  • Digital Bits: 8
  • LED Color: Red
  • Interface: SPI
  • Other: More than 2 module can be serial connected
  • Size: 122x20x12mm(4.8x0.8x0.5'')
  • 8 digital bits serial LED display x1
