Power Shield (Arduino Compatible)
$8.90
SKU: DFR0105
The Arduino power shield provides 1.25-12V output with a 3A peak current from a 4.5-35V input, featuring voltage measurement and switch control via Arduino pins.
Most project of Arduino may need more than two voltage supply. When feed with from 4.5-35V, this arduino power shield able to provide a voltage range from 1.25-12V with 3A peak current. Ideal for servo control and other non-standard components. With this arduino power supply shield, your Arduino now have one power supply for all.
It has be build-in voltage measuring function which mapping the output voltage to Arduino analog pin 0. It can be controlled by Arduino digital Pin13 to switch on/off.
  • Supply voltage:4.5-35V
  • Output voltage:1.25-12V
  • Output current: 2A (3A peak)
  • Max output power: 15W 3A@5V
  • Efficiency:90%
  • Power Shield    x1
