This aluminum electrolytic capacitor assortment provides a practical selection of commonly used decoupling and filtering components for electronics prototyping and circuit design. The capacitor kit contains twelve value groups covering capacitances from 1µF to 470µF with voltage ratings of 16V, 25V, and 50V, enabling flexible use across low‑voltage analog and digital circuits. Such a mixed capacitor collection supports rapid testing, breadboard prototyping, and custom PCB development by ensuring frequently required electrolytic values remain readily available during circuit assembly and troubleshooting.
Wide Capacitance Coverage for Prototyping
This electronic component assortment spans twelve capacitor specifications, ranging from small decoupling values such as 1µF to larger bulk filtering options up to 470µF. Such coverage allows engineers, makers, and students to quickly select suitable capacitance levels for power smoothing, signal coupling, or energy buffering tasks. The mixed-value electrolytic capacitor set simplifies experimentation and eliminates repeated component sourcing when building or modifying analog circuits, embedded systems, and power regulation stages on breadboards or custom circuit boards.
Convenient Assortment for Circuit Development
Each capacitance value group includes ten pieces, forming a balanced electronics parts kit suitable for laboratory work, maker workshops, and repair benches. This decoupling capacitor pack supports both quick prototyping and small-batch circuit assembly, offering reliable components for filtering noise, stabilizing voltage rails, and supporting transient current demands. The organized capacitor assortment reduces development interruptions by keeping commonly used electrolytic components readily available for experimentation and PCB-level implementation.
Such a multi-value capacitor collection fits naturally into electronics laboratories, maker spaces, and educational environments focused on circuit experimentation. From stabilizing power supplies and smoothing rectified outputs to supporting signal coupling in audio circuits, this electrolytic capacitor kit provides essential passive components for rapid prototyping, electronics repair, and practical hardware development workflows.
Basic Parameters
