3.7V Polymer Lithium Ion Battery - 1000mAh (Discontinued)
SKU: FIT0120
Discontinued
Sorry to say that since Lipo Battery cannot be shipped through DHL/FedEx/EMS, so this product is discontinued now.
These are very slim, extremely light weight batteries based on the new Polymer Lithium Ion chemistry. This is the highest energy density currently in production. Each cells outputs a nominal 3.7V at 1000mAh! Comes terminated with a standard 2-pin JST connector - 2mm spacing between pins. These batteries require special charging. Do not attempt to charge these with anything but a specialized LiPo charger.
Battery includes built-in protection against over voltage, over current, and minimum voltage.
Note: Be careful with the JST connectors. They can stick in pretty good and tugging on them can damage the connector. Check this tutorial for an easy way to remove them safely.
The battery can supply power to FIO and charged by the FIO USB.
FIO is the picture is NOT included.
  • Votage: 3.7v
  • Capacity:1000mAh
  • Continuous Discharge Rating: 1C
  • Maximum Discharge Rating: 1C
  • Connector: PH2.0 JST connector
  • Cable Length: Approx. 70mm (2.76'')
  • Size: 49x32x7mm (1.96x1.22x0.23 inches)
  • Weight: 25g
  • 1000mAh 3.7V Lipo Battery with PH2.0 JST connector x1
How to make a cool game console with UNIHIKER (SBC)
Projects How to make a cool game console with UNIHIKER (SBC)
RRoy
Jan 08, 2024
Making a Temperature-Detecting 'Portal Gun' with Unihiker
Projects Making a Temperature-Detecting 'Portal Gun' with Unihiker
Afra
Nov 22, 2023
DIY A Simple Three-axis Accelerometer Data Logger
Projects DIY A Simple Three-axis Accelerometer Data Logger
Frances
Mar 02, 2023
Make a Weather Station Using Environmental Sensor
Projects Make a Weather Station Using Environmental Sensor
Frances
Oct 28, 2022
