20W Adjustable DC-DC Boost Converter With Digital Display
$7.50
SKU: DFR0123
A 20W adjustable DC-DC boost converter with digital display offers 3-32V input, 5-35V output, 94% efficiency, and protection features for various applications.
20W Adjustable DC-DC Boost Converter with Digital Display is a compact step‑up power module designed for applications requiring a higher output voltage than the input source. Based on a professional boost controller operating at 400kHz, this adjustable voltage regulator supports a wide input range of 3–32V and delivers an adjustable 5–35V output. Integrated digital voltage monitoring enables convenient real‑time measurement while maintaining a voltage accuracy of ±0.05V. With conversion efficiency reaching up to 94%, this compact DC‑DC step‑up module provides stable and efficient power conversion for battery systems, portable electronics, and custom power supply designs.
Wide Adjustable Step‑Up Voltage Range
This digital DC‑DC boost module converts low input voltage into a higher adjustable output voltage, supporting 3–32V input and 5–35V output ranges. Such flexibility allows deployment across numerous power scenarios including battery packs, transformer outputs, and low‑voltage power sources that require voltage boosting. A high switching frequency of 400kHz enables stable operation and efficient energy transfer while maintaining compact circuit size, making this adjustable boost regulator suitable for embedded electronics, mobile devices, and custom regulated power supplies.
Integrated Digital Voltmeter with Self‑Calibration
An onboard digital display continuously monitors voltage conditions, providing convenient real‑time observation of either input or output voltage. Built‑in self‑calibration functionality allows voltage readings to be fine‑tuned across the entire measurement range with a single calibration process. Adjustable compensation between −5 and +5 steps enables improved measurement precision, ensuring accurate monitoring in variable electrical environments. This embedded digital voltmeter significantly simplifies debugging and adjustment during prototype development and system integration.
Efficient Operation with Protection Features
This high‑efficiency boost power module reaches conversion efficiencies up to 94%, helping reduce heat generation and power loss during operation. Integrated safety mechanisms include overheating protection and short‑circuit protection to improve operational reliability in demanding electronics environments. Screw terminals simplify wiring while additional solder pads support permanent connections, offering flexibility for both quick testing and fixed installations in industrial equipment, DIY power systems, and automotive electronics.
Compact design, adjustable output capability, and integrated voltage monitoring make this DC‑DC step‑up converter suitable for numerous voltage‑boosting scenarios. Typical uses include DIY regulated power supplies, portable battery voltage boosting, automotive notebook power systems, industrial control equipment, and embedded electronics projects that require stable higher‑voltage output from low‑voltage sources.
  • Wide input voltage range: 3V–32V
  • Adjustable output voltage from 5V to 35V
  • Integrated digital voltmeter with self‑calibration mode
  • High conversion efficiency up to 94%
  • Built‑in overheating protection and short‑circuit protection
  • Screw terminal connectors and solder pads for flexible wiring
  • DIY adjustable regulated power supplies
  • Battery voltage boosting systems
  • Automotive notebook power supplies
  • Industrial equipment voltage boosting
  • Portable electronics power conversion
  • Embedded electronics prototyping
    Electrical Parameters
  • Input Voltage: 3V–32V (under 5V, the digital display does not work), the best working voltage is 5V–32V
  • Output Voltage: 5V–35V
  • Switching Frequency: 400khz
  • Rectification Method: non-synchronous rectification
  • Input Current: 4A (peak)
  • Conversion Efficiency: 94% (the greater the voltage difference, the lower the efficiency)
  • Output Ripple: 50mv (the higher the voltage, the greater the current, the greater the ripple)
  • Load Regulation Rate: ±0.5%
  • Voltage Adjustment Rate: ±0.5%
  • Working Temperature: -40℃~+85℃
  • 20W Adjustable DC-DC Boost Converter With Digital Display x1
  • Review
    kyle.benson Oct 12, 2023
    Works as needed. Thanks!
