Sealed Membrane 4×4 Button Pad with Sticker is a compact human–machine input interface designed for embedded electronics, interactive control panels, and prototyping systems. This 16‑key matrix keypad provides a reliable tactile interface for entering commands, triggering functions, or navigating menus in microcontroller projects. The thin membrane structure combines flexible circuitry with a durable sealed surface, enabling dependable operation in compact enclosures or educational prototypes. Adhesive backing allows rapid installation on flat surfaces, transforming this matrix keypad module into a convenient control interface for robotics, automation systems, and microcontroller-based electronics.
Compact 16‑Key Matrix Input Design
This membrane keypad module features a classic 4×4 matrix layout delivering sixteen independent buttons through a row‑column scanning structure. Such architecture minimizes required I/O pins while enabling full numeric and functional input capability. The matrix keypad design integrates easily with microcontroller platforms including Arduino, embedded development boards, and custom electronics. For prototyping environments, the keypad provides an intuitive command interface suitable for password entry systems, device configuration panels, or menu navigation controls in embedded projects.
Thin Sealed Membrane with Adhesive Mounting
A flexible membrane construction protects the internal switch contacts from dust and mechanical wear while maintaining a lightweight and low‑profile structure. The sealed keypad surface improves durability compared with exposed mechanical buttons, making the input module suitable for portable electronics and educational kits. Integrated adhesive backing enables quick attachment to project enclosures, instrument panels, or prototyping boards without additional mounting hardware. This slim membrane keypad therefore serves as a practical user‑input solution for compact embedded systems.
Practical integration appears in embedded automation and IoT demonstrations such as the How to Make an Mail Alarm project, where keypad input works alongside motion detection and an FireBeetle ESP32 IOT Microcontroller. Combined with components including the Digital Infrared Motion Sensor For Arduino, status LEDs such as the 5mm LED Pack (50 pcs), and supporting electronics like the 220R Resistor, this numeric keypad interface enables practical control panels, security inputs, and interactive embedded systems.
Basic Parameters
Physical Characteristics
Dec 13, 2025
The Sealed Membrane 4×4 Button Pad with Sticker is a simple, reliable, and affordable input solution for embedded applications. While it doesn’t offer mechanical feedback, its durability, compact form, and ease of use make it an excellent choice for control panels and Arduino-based projects.
