LED Voltage Meter (Red)
$1.50
SKU: DFR0130-R
Standalone DC voltage meter measures 3V-30V with 1% accuracy, ideal for battery display. Available in green, blue, and red. Easy to use, no extra circuits needed.
Purchase this product and earn 15 reward points, which are tied to VIP membership program. Learn More >
LED DC Voltage Meter (3–30V) is a compact standalone digital panel gauge designed for quick DC voltage monitoring without external circuitry. This miniature voltage display module measures electrical potential from 3.0V to 30V DC with 1% accuracy, making the unit suitable for battery-powered electronics, robotics builds, and embedded hardware diagnostics. A simple two‑wire connection enables instant voltage readout, eliminating the need for additional signal conditioning boards. The small footprint and bright LED numeric display allow seamless integration into battery packs, portable equipment, DIY robotics controllers, and embedded monitoring systems requiring clear, real‑time voltage feedback.
Direct Two‑Wire Voltage Measurement
This digital voltage monitoring module operates as a fully standalone measurement tool. A direct two‑wire connection to the measured power source enables immediate voltage readout without external resistors, controllers, or signal conversion circuits. Such simplified integration reduces wiring complexity in embedded electronics and robotics builds. The compact DC voltage display board therefore works effectively for battery level indication, power supply diagnostics, and quick voltage verification during prototyping, where immediate measurement feedback is required without additional electronics.
Wide 3–30V Measurement Range with Reliable Accuracy
This miniature DC voltage indicator supports measurement from 3.0V to 30V DC with approximately 1% accuracy and a refresh rate of 2 Hz. Such performance enables dependable monitoring of lithium battery packs, DC adapters, motor drivers, and mobile robotic power systems. Consistent refresh updates ensure voltage changes remain visible in real time, supporting safer power management and quick troubleshooting during electronics development, battery testing, or portable equipment maintenance.
Bright LED Display with Multiple Color Options
This LED voltage monitoring gauge features a high‑visibility numeric display designed for clear reading in embedded hardware panels and robotics enclosures. Three LED color variants are available to suit different system aesthetics or visual coding requirements: green, blue, and red. Distinct color options allow voltage indicators to match project themes or differentiate multiple power rails inside complex electronic assemblies.
This compact voltage measurement display supports a wide range of practical electronics applications. From battery level indicators in mobile robots and portable devices to embedded DC supply monitoring in DIY electronics and laboratory prototypes, this standalone voltage display module delivers fast, clear voltage feedback with minimal wiring and reliable accuracy.
  • Standalone DC voltage measurement module
  • Measurement range: 3.0–30V DC
  • Approximate measurement accuracy of 1%
  • Simple two‑wire connection for direct voltage reading
  • 2 Hz refresh rate for real‑time voltage updates
  • Bright LED numeric display for clear visibility
  • Available in green, blue, and red display variants
  • Suitable for battery level monitoring and embedded electronics
  • Battery level monitoring systems
  • Robotics power supply diagnostics
  • Portable electronics voltage display
  • DIY electronics prototyping
  • Embedded DC power monitoring
  • Laboratory power supply indication
    Electrical Parameters
  • Measure Voltage:3.0-30V DC
  • Refresh Rate:2 Hz
  • Accuracy:1%
  • LED Voltage Meter (Green) x1
  • Only 3 Left
