DFRduino Mega1280 (Arduino Mega Compatible)
$21.00
SKU: DFR0003
The microcontroller board features an ATmega1280 chip, 54 digital I/O pins, 16 analog inputs, and 4 UARTs, ideal for cost-effective projects.
Purchase this product and earn 210 reward points, which are tied to VIP membership program. Learn More >
DFRduino Mega1280 is a microcontroller board based on the ATmega1280. It has 54 digital input/output pins, 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. Because it has bootloader, it can download programs directly from USB. There is no need to use other external programs to burn.
It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with an AC-to-DC adapter or battery to get started. The 128KB FLASH space allows it to completely replace the Arduino MEGA2560 in some of its intermediate and lightweight applications. Anyway, this is a cost-effective controller.
  • Microcontroller: ATmega1280
  • Operating Voltage: 5V
  • Input Voltage: 3-16V (20V max)
  • Digital I/O Pins: 54 (of which 14 provide PWM output)
  • Analog Input Pins: 16 I/O
  • Flash: 128 KB of which 4 KB used by bootloader
  • SRAM: 8kb
  • EEPROM: 4kb
  • Frequency: 16MHz
  • DFRduino Mega1280 (Arduino Mega Compatible) x1
    DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Blog DFRobot Arduino-Compatible Microcontrollers Selection Guide
    Jul 30, 2020
    mohamad.udayana Jul 02, 2024
    fast delivery, the best part.
    Mattia. Nov 26, 2021
    A cheaper solution to Mega 2560, good.
    Only 5 Left
