6xAA Battery Holder with DC2.1 Power Jack provides a practical power solution for embedded electronics, robotics, and portable prototyping platforms. This multi-cell AA battery pack converts six standard batteries into a stable external supply suitable for development boards and standalone circuits. When using NiMH or NiCd cells, the holder forms a 7.2V rechargeable battery pack, while alkaline cells produce a 9V supply. The integrated DC2.1 power connector enables convenient direct connection with popular controllers such as Arduino, eliminating complex wiring and simplifying mobile project deployment.
Flexible Multi‑Chemistry Battery Configuration
This six‑slot AA battery carrier supports multiple common battery chemistries, allowing flexible power system design across different project requirements. NiMH or NiCd rechargeable cells create a reliable 7.2V rechargeable pack suitable for repeated experimentation and robotics testing, while alkaline batteries deliver approximately 9V for applications requiring higher voltage. Such versatility allows the portable power module to function in educational experiments, rapid prototyping setups, and field electronics where battery availability or recharge capability may vary.
Integrated DC2.1 Power Jack for Direct Board Connection
An onboard DC2.1 barrel connector transforms the AA battery enclosure into a ready‑to‑use external power source for development boards and embedded systems. This integrated output interface allows quick connection to controller boards, eliminating the need for custom cables or soldered terminals. The battery power module therefore becomes particularly convenient for mobile robotics, portable sensor platforms, and educational prototypes where clean power routing and rapid hardware setup significantly improve development efficiency.
Portable electronics, robotics prototypes, educational experiments, and field‑deployable embedded projects benefit from a compact AA battery solution with reliable output connectivity. This DC barrel‑equipped battery holder simplifies powering microcontroller platforms, standalone sensor nodes, and mobile development boards while maintaining compatibility with widely available AA cells.
Basic Parameters
Mechanical Dimensions
