The 2‑Pin 2.0mm Mating Connector Housing and Crimp Pin Kit provides a compact wiring solution for low‑power electronics, sensor modules, and embedded development projects. This connector assembly set contains durable 2‑pin 2.0mm pitch housings paired with precision crimp terminals designed for 28–26 AWG wires. Such compact cable connectors enable reliable detachable wiring between boards, sensors, and peripheral devices while maintaining a clean cable layout. The small‑pitch connector format suits prototyping environments, robotics wiring, and compact electronic assemblies where stable signal connections and efficient cable management remain essential.
Reliable Crimp Connection for Small‑Gauge Wiring
Each crimp terminal supports 28–26 AWG wires, enabling secure mechanical and electrical contact for lightweight signal and power lines. Proper crimping ensures stable conductivity and reduces the risk of loose connections during vibration or repeated handling. This compact wiring connector system supports common prototyping and embedded electronics tasks where dependable cable terminations and quick assembly are required. The precision‑fit terminals slide into the connector housing to form a stable locking interface suitable for repeated connection cycles.
Compact 2.0mm Pitch for Space‑Efficient Designs
A 2.0mm pitch connector format enables dense wiring layouts in compact electronics projects. This small‑footprint connector housing integrates easily with miniature sensors, controller boards, and modular electronics where board space and cable routing flexibility matter. The lightweight connector set supports rapid prototyping, equipment repair, and custom cable fabrication without increasing system size. Such compact electrical connectors remain well suited for robotics builds, embedded hardware experiments, and modular electronic assemblies requiring organized and detachable wiring.
This compact connector and terminal set supports cable assembly for prototyping, sensor wiring, robotics projects, and embedded electronics maintenance. Reliable crimp terminals combined with small‑pitch housings enable quick creation of custom cables for modular electronic systems, helping maintain organized wiring and dependable electrical connections across development boards, sensors, and peripheral modules.
Basic Parameters
