This 3-pin 2.0mm connector housing and crimp pin kit provides a compact and reliable solution for building or repairing fine‑pitch wiring harnesses in electronics projects. The connector accessory set contains ten 3‑pin 2.0mm (0.08") mating housings along with thirty precision crimp terminals designed for small‑gauge wire. Supporting 28–26 AWG conductors, this wiring interface component enables clean signal routing and dependable electrical contact in compact embedded systems, sensor modules, and custom cable assemblies. The lightweight connector hardware simplifies prototyping and small‑batch cable production while maintaining stable mechanical retention and consistent electrical performance across repeated connections.
Compact 2.0mm Pitch Connection System
A fine 2.0mm pitch layout allows this miniature connector system to fit easily into space‑constrained electronics assemblies where larger headers are impractical. Each 3‑pin housing supports organized signal routing for power, ground, and data lines while maintaining consistent alignment with matching board‑side connectors. The compact form factor makes this cable termination accessory especially useful for small sensor modules, embedded control boards, robotics subsystems, and custom wiring harnesses where neat cable management and secure electrical mating are essential for long‑term reliability.
Reliable Crimp Terminals for 28–26 AWG Wire
Each included crimp terminal is designed to securely terminate 28–26 AWG conductors, forming stable electrical connections when properly crimped and inserted into the 3‑pin housing. The precision‑formed metal contacts help maintain strong conductivity while minimizing connection resistance. Combined with the locking plastic housing, this crimp connector solution supports repeated plug‑and‑unplug cycles without loosening contacts. Such characteristics make this wiring accessory suitable for prototyping environments, custom cable fabrication, educational electronics builds, and maintenance of modular electronic systems.
This compact connector and crimp terminal set supports a wide range of electronics assembly tasks, including custom cable creation, sensor wiring, and modular hardware prototyping. The small‑pitch connector format enables organized multi‑wire connections between development boards, peripheral modules, and embedded devices while maintaining a tidy and serviceable wiring structure in robotics projects, DIY electronics, and laboratory test setups.
