APC220 Radio Communication Module
$40.00
SKU: TEL0005
  • $39.50 2+ items
  • $38.50 5+ items
  • $36.00 10+ items
APC220 radio module offers a wireless data communication solution with UART/TTL interface, 1000m range, and high sensitivity. Includes two modules and antennas.
Purchase this product and earn 400 reward points, which are tied to VIP membership program. Learn More >
The APC220 radio module provides a simple and economic solution to wireless data communications. Integrates an embedded high speed microprocessor and high performance IC that creates a transparent UART/TTL interface, and elminates any need for packetizing and data encoding. If you are looking for a low-cost solution with better range performance, this has being our customer choice for a long time now.
With this module, you can build wireless projects in an easy way.
Recommended Alternatives
If you are looking for similar wireless UART communication solutions, we recommend:
  • XBee S2C ZigBee (Wire Antenna) — closest plug-and-play replacement with stable transparent serial communication
  • LoRa Radio Module - 868MHz — long-range upgrade option (lower power, much longer distance)
  • LoRa Radio MESH Module - 433MHz — flexible mesh networking for multi-node IoT projects
    • Voltage: 5V
    • Transmit distance up to 1000m (line of sight) @9600 bps
    • 256 bytes data buffer
    • High sensitivity (-112dbbm @9600 bps)
    • GFSK modulation
    • UART/TTL interface
    • Embedded watch dog
    • Size: 37 x 17 x 6.5 mm (1.46x 0.67x 0.26 in)
    Alberto. Nov 08, 2025
    Este producto promete Excelente producto! Full recomendado
    Out Of Stock
