400 Tie Point Interlocking Solderless Breadboard - Crystal
$3.45
SKU: FIT0096-C
  • $3.40 2+ items
  • $3.35 5+ items
  • $3.30 10+ items
A compact solderless breadboard with 400 tie points, removable power rails, and interlocking capability for flexible project configurations. Dimensions: 8.2cm x 6.2cm.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
The 400 Tie Point Interlocking Solderless Breadboard is a cute half size breadboard, good for small projects. It is 8.2cm(3.23") x 6.2cm(2.44") in size with a standard double-strip in the middle and two power rails on both sides. You can pull the power rails off easily to make the breadboard as thin as 3.5cm and stick it onto an Arduino protoshield. You can also cut these in half with a saw to create 2 tiny breadboards, or "snap" these breadboards together either way to make longer or wider breadboards.
  • 400 Tie Points
  • Self-adhesive
  • Can be interlocked for larger projects
  • 2 power lanes
  • Horizontal: 1-30
  • Vertical: A-J
  • Dimensions: 8.2cm x 6.2 cm(3.23"x2.44")
  • Crystal
  • Clear 400 tie point bread board x1
Bryan.Humphrey May 18, 2023
This is a very good and useful prototyping tool to have.
Ronald.Sdeyb Nov 14, 2021
Very good to explain how a breadboard works in class
Only 6 Left
