USB Serial Light Adapter (Arduino Compatible)
$11.95
SKU: DFR0164
USB-to-serial converter with Atmega8U2, mini-USB, 5 pins including RX/TX, switchable 3.3/5V output, works with various Arduino boards. Includes schematics.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
USB Serial Light Adapter (Arduino Compatible) is a compact USB‑to‑TTL communication board designed to simplify programming and serial communication for microcontroller development platforms. Built around the Atmega8U2 configured as a USB‑to‑serial converter—the same interface chip used on the Arduino Uno—this USB interface module enables direct connection between a computer and embedded boards without relying on external FTDI chips. Standard USB COM drivers ensure straightforward operation across most operating systems, making this USB‑to‑UART adapter a practical bridge for prototyping, debugging, and firmware uploading within the Arduino ecosystem and other microcontroller projects.
Atmega8U2 USB‑to‑Serial Architecture
This USB communication interface integrates an Atmega8U2 microcontroller programmed to function as a reliable USB‑to‑UART converter. The firmware relies on standard USB COM drivers commonly bundled with development environments, reducing setup complexity during board connection and firmware upload workflows. Compared with traditional FTDI solutions, this embedded converter architecture delivers dependable serial communication while maintaining compatibility with many development boards. For certain Windows environments, driver installation may still be required, with drivers typically included in the Arduino IDE package.
Flexible Power Output and Full Serial Pin Access
A selectable 3.3V or 5V output allows this USB serial interface board to adapt to different logic‑level requirements through a simple jumper configuration. The adapter exposes essential UART pins including RX for receiving data and TX for transmitting data, along with power, ground, and reset connections for streamlined programming workflows. Integrated RX and TX indicator LEDs provide immediate visual feedback of serial activity, helping diagnose communication status during debugging and firmware uploading tasks.
Designed for Broad Board Compatibility
This compact USB programming adapter connects easily to several microcontroller platforms including the Arduino Ethernet, Mini, Mini Pro, LilyPad, LilyPad Simple, and Fio development boards. The onboard mini‑USB connector simplifies direct PC connection while maintaining a lightweight footprint suitable for embedded projects. Such compatibility makes this USB‑to‑TTL converter particularly useful in rapid prototyping environments, educational laboratories, and robotics control systems where consistent serial communication and quick firmware uploading are essential.
Reliable USB‑to‑serial bridging makes this adapter valuable for embedded development tasks ranging from firmware uploading to debugging serial output streams. Applications include robotics prototyping, microcontroller experimentation, educational electronics labs, and portable embedded systems requiring a compact USB programming interface. Stable communication, selectable logic levels, and broad board compatibility position this serial converter module as a practical development tool for engineers, makers, and learning environments.
  • Atmega8U2 microcontroller configured as a USB‑to‑serial converter
  • Standard USB COM driver support for simplified connectivity
  • Selectable 3.3V or 5V output via jumper
  • Exposed RX, TX, VCC, GND, and Reset pins for direct programming
  • Integrated RX/TX LED indicators for serial activity monitoring
  • Mini‑USB connector for convenient PC connection
  • Compatible with multiple Arduino development boards
  • Microcontroller firmware uploading
  • Serial debugging and data monitoring
  • Embedded systems development
  • Robotics controller programming
  • STEM electronics education projects
    Basic Parameters
  • Output Voltage: 3.3/5V (switchable via jumpers)
  • Physical Dimensions
  • Dimensions: 40 X 21mm (1.57 x 0.83")
  • USB Serial Light Adapter (Arduino Compatible) x1
  • Only 12 Left
