120W DC-DC Converter 12V@10A
$13.00
SKU: FIT0170
Waterproof DC-DC converter with 15-40V input, outputting 12V@10A. Features include multiple protections, high efficiency, and a compact, durable design.
Purchase this product and earn 130 reward points, which are tied to VIP membership program. Learn More >
120W DC‑DC Converter is a rugged waterproof power conversion module designed to transform a wide 15–40V DC input into a stable 12V output with up to 10A current capacity. This high‑power voltage regulator serves as a dependable power source for embedded computers, mobile robotics platforms, automotive electronics, and other field‑deployed electronics. Featuring a sealed enclosure for environmental resistance and high conversion efficiency, this industrial‑grade DC voltage step‑down unit supports stable system operation while minimizing heat generation, making the power module suitable for demanding outdoor or mobile applications requiring consistent 12V power delivery.
Stable 12V High‑Current Power Conversion
This DC step‑down power converter efficiently transforms 15–40V DC input into a regulated 12V output capable of delivering up to 10A of current. Such high output capacity allows the voltage regulation module to power embedded PCs, robotics controllers, surveillance systems, and other high‑load electronics that require reliable 12V supply rails. High conversion efficiency reaching 90% significantly reduces wasted energy and limits thermal buildup, allowing the power regulation unit to maintain stable electrical performance even when supporting power‑hungry computing or electromechanical systems.
Sealed Waterproof and Shock‑Resistant Housing
A fully enclosed waterproof and shockproof case protects internal circuitry from moisture, dust, and vibration. Such rugged mechanical protection makes the industrial DC power regulator suitable for outdoor installations, mobile robotics platforms, vehicles, and other harsh environments where exposed electronics often fail. Durable housing design improves operational reliability during long‑term deployments while maintaining stable electrical performance in environments subject to humidity, splashes, or physical shocks. This sealed structure greatly expands deployment possibilities beyond standard indoor power supplies.
Comprehensive Electrical Protection System
Multiple built‑in protection mechanisms safeguard connected electronics and ensure stable long‑term operation. The DC‑DC conversion module integrates overvoltage protection, overcurrent protection, overheat protection, and short‑circuit protection to prevent electrical damage during abnormal conditions. These layered safeguards automatically respond to unsafe operating states such as excessive load current or thermal stress, reducing the risk of system failure. Such protective circuitry enhances reliability for robotics systems, embedded computing platforms, and other mission‑critical electronics operating in remote or unattended environments.
This waterproof DC power conversion module enables reliable energy regulation for embedded computing systems, robotics platforms, and vehicle‑mounted electronics requiring stable 12V supply. High current capacity, rugged enclosure protection, and integrated safety features make this industrial step‑down converter well suited for mobile robotics, outdoor automation equipment, surveillance infrastructure, and field‑deployed electronic systems where dependable power conversion is essential for continuous operation.
  • Supports 15–40V DC input with regulated 12V output
  • Maximum output current up to 10A
  • Overvoltage protection
  • Overcurrent protection
  • Overheat protection
  • Short‑circuit protection
  • Waterproof and shockproof enclosure
  • High efficiency up to 90% with reduced heat generation
  • Embedded PC power supply systems
  • Mobile robotics platforms
  • Automotive electronic systems
  • Outdoor monitoring equipment
  • Industrial automation power regulation
  • Field‑deployed electronic devices
    Electrical Parameters
  • Input Range: 15-40V DC
  • Output: 12V DC
  • Output Current: 10A
  • Efficiency: 90%
  • Maximum working temperature: 80 ℃
  • Physical Dimensions
  • Size: 74 X 74 X 32mm (2.91x2.91x1.26")
  • Weight: 0.28Kg
  • 120W DC‑DC Converter x1
  • Out Of Stock
