240W DC-DC Converter 24V@10A
$45.00
SKU: FIT0172
Waterproof DC-DC converter with 8-18V input, outputs 24V@10A. Features protection systems, high efficiency, and is ideal for robots. Size: 74x74x32mm.
Purchase this product and earn 450 reward points, which are tied to VIP membership program. Learn More >
This is a waterproof DC-DC converter. With 8-18V DC input, it converts to 24V@10A which is an ideal supply for robots.
Note: Input voltage of 12V or above can reach 240W. Transmission line with line diameter of 2.5 square mm or above should not be too long.
The power input can be supplied by battery for better effect.
  • Overvoltage protection
  • Overcurrent protection
  • Overheat protection
  • Short-circuit protection
  • Waterproof and shockproof case
  • High efficiency and less heat
  • Input Rage:  8-18V DC
  • Output: 24V DC
  • Output Current: 10A(max)
  • Size: 74 X 74 X 32mm(2.91x2.91x1.26")
  • Efficiency: 82%-88%
  • Weight:0.28Kg
  • Maximum working temperature:80 ℃
  • 240W DC-DC Converter(FIT0172)  x1
Only 10 Left
