EL Wire Male/Female Set (30cm)
$0.99
SKU: FIT0177
  • $0.95 2+ items
  • $0.91 5+ items
  • $0.85 10+ items
Pair of in-line power wire connectors with JST 2.5mm assembly; includes male and female connectors for EL wire and inverter connection. 30cm length.
Purchase this product and earn 10 reward points, which are tied to VIP membership program. Learn More >
This in-line power wire connector pair provides a practical detachable wiring solution for electronics projects requiring quick connection and disconnection. Featuring a JST-style free‑hanging cable assembly with a secure latching structure, this connector cable enables stable electrical linkage between EL wire and compatible inverters. The assembly integrates a standard 0.1" (2.54mm) pitch interface, supporting convenient integration with many prototyping systems and lighting setups. With a 30cm pre‑wired lead and matched male–female terminals, this wiring accessory simplifies modular circuit design while maintaining reliable electrical continuity in compact installations.
Secure JST Latching Cable Assembly
This detachable power connector cable uses a JST 2.5mm style locking interface designed for stable free‑hanging cable connections. The latching mechanism ensures firm mechanical engagement during operation, reducing accidental disconnection in portable electronics or lighting installations. A matched male and female connector pair allows quick plug‑and‑play wiring while preserving polarity alignment when correctly installed. Such structure makes the cable assembly well suited for EL lighting setups, inverter connections, and modular electronic builds that benefit from dependable detachable power wiring.
Convenient Integration for EL Wire Systems
This EL wire connector lead functions as the matching cable required for linking EL wire to compatible inverters. A standard 0.1" (2.54mm) pitch terminal provides compatibility with many prototyping connectors and wiring interfaces, enabling flexible integration into lighting electronics or experimental circuits. The 30cm cable length offers comfortable routing inside enclosures or installations while maintaining tidy wiring layouts. Careful polarity verification remains essential when deploying this wiring harness for DC power or signal connections to prevent circuit damage.
Reliable detachable wiring greatly improves maintainability in lighting electronics and rapid‑prototyping environments. This JST connector cable assembly supports EL wire lighting projects, inverter power connections, wearable lighting systems, and experimental electronics requiring modular wiring. A compact cable length and locking connector structure allow stable integration in decorative lighting builds, portable installations, and educational electronics projects where quick replacement or safe disconnection of wiring is necessary.
  • JST 2.5mm style in-line connector cable with secure latch
  • Standard 0.1" (2.54mm) pitch connector interface
  • Matched male and female connector pair for detachable wiring
  • Designed for EL wire and inverter connections
  • 30cm cable length suitable for compact installations
  • EL wire lighting systems
  • EL inverter power connections
  • Detachable wiring for electronics projects
  • Wearable lighting installations
  • Prototype circuit power connections
    Basic Parameters
  • Connector Pitch: 0.1" (2.54mm)
  • Compatibility: Used with all sizes of EL wire and Inverters
  • Connector Type: One Male Connector + One Female Connector
  • Wire Length: 30cm(12")
  • In-line Power Wire Connector x2
  • EL Wire Male/Female Set (30cm)
