EL Wire Male/Female Set (30cm)
$0.99
SKU: FIT0177
  • $0.95 2+ items
  • $0.91 5+ items
  • $0.85 10+ items
Pair of in-line power wire connectors with JST 2.5mm assembly; includes male and female connectors for EL wire and inverter connection. 30cm length.
Purchase this product and earn 10 reward points, which are tied to VIP membership program. Learn More >
This product includes a pair in-line power wire connectors. If you have a project where you'd like to be able to detach the wiring, this wire will fit the bill. Its a JST 2.5mm 'free hanging' cable assembly that latches strongly. This is the matching connector to the inverter. It is required to connect EL wire to the inverter! 0.1" (2.54mm) pitch connector on the end. Warnings: If you're using this for DC power or signal,
please triple-check the polarity before plugging it in!
  • 0.1" (2.54mm) pitch connectors
  • Used with all sizes of EL wire and Inverters
  • One Male Connector
  • One Female Connector
  • Can be attached to any of our Wires and Inverters
  • Length of wire: 30cm(12")
  • in-line power wire connector x2
