10 Sets M3 * 20 Hexagonal Standoffs Mounting Kit
$2.90
SKU: FIT0183
10-pack of standoffs with screws and nuts, ideal for circuit boards and multi-level robot chassis. Includes M3 size standoffs, screws, and nuts.
M3 20mm hexagonal male–female standoffs provide a simple and reliable mechanical spacing solution for electronic assemblies. This hardware mounting kit is designed for securing circuit boards, sensor modules, and structural plates while maintaining precise vertical separation between layers. The threaded spacer design enables stable stacking of boards and brackets, making the hardware suitable for robotics frames, prototyping platforms, and embedded system installations. With integrated screw and nut accessories included in the package, this mechanical support set simplifies multi-layer electronics construction and improves structural rigidity in compact electronic builds.
Stable Multi‑Layer Board Spacing
Each hexagonal spacer provides a fixed 20mm separation between mounted components, allowing circuit boards, shields, or structural plates to be stacked safely without electrical contact. The male–female threaded configuration enables vertical expansion of assemblies while maintaining strong mechanical alignment. Such structural spacing hardware is widely used in robotics platforms, multi‑board embedded systems, and sensor arrays where consistent board clearance improves airflow, wiring management, and overall system reliability.
Complete Mounting Hardware Set
Every package includes ten threaded standoffs together with matching screws and nuts, forming a ready‑to‑use fastening solution for electronics projects. The included hardware eliminates the need to source additional fasteners when assembling development boards or mechanical frames. This integrated mounting kit supports efficient prototyping and mechanical installation for sensors, controller boards, and robotic chassis structures, ensuring stable attachment and convenient assembly during hardware development or educational builds.
Mechanical spacer hardware of this type is commonly used in robotics chassis construction, sensor mounting brackets, layered controller platforms, and general electronics prototyping. The threaded standoff design allows fast installation while maintaining reliable structural spacing between components, supporting organized wiring layouts and durable multi‑board assemblies in maker projects, laboratory prototypes, and educational engineering environments.
  • M3 hexagonal male–female threaded standoff design
  • 20mm fixed spacing for multi‑layer electronic assemblies
  • Suitable for circuit boards, sensors, and structural mounting
  • Includes screws and nuts for complete installation
  • Ideal for robotics chassis and prototyping platforms
  • Robot chassis structural assembly
  • Multi-layer circuit board mounting
  • Sensor module installation
  • Electronics prototyping platforms
  • Embedded system mechanical support
    Basic Parameters
  • Standoff length:20 mm(0.79")
  • Gross weight: 30g
  • M3 * 20mm(0.79") Hexagonal Male/Female standoffs x10
  • M3 * 6mm(0.24") screws x10
  • M3 nuts x10
  • Only 19 Left
