Note: This Xbee shield should be used with other wireless modules to realize wireless functions like WiFi, Bluetooth, etc., and it doesn’t have wireless capability itself.
This low-power Xbee shield for Arduino allows you to add wireless capability to your Arduino projects using Xbee radios more easily and cost-effectively!
The shield is easy to use and offers reliable transmission of critical data between devices. It can be directly stacked on top of Arduino Uno / Leonardo and Mega. Besides, the shield provides a 5-3.3V voltage converter to allow 3.3V communication modules to interface Arduino 5V system.
The compatibility of this Xbee shield is extremely good. It supports not only zigbee module, but also wifi and bluetooth module, such as Wifi bee, Bluetooth 2.0 Bee Ready Board , Bluetooth 4.0 Bee Ready Board, and the most popular Esp8266 wifi bee module.
For some IoT projects, you may need dual xbee modules to convert bluetooth to wifi or vice verse. The Bees Shield for Arduino could fit the requirement.
The Xbee module is widely used in the United States, Canada, Australia, Israel and Europe. The establishment of RF communication does not require any configuration and the module's default configuration supports a wide range of data system applications. You can also use a simple AT command to advanced configuration. An OEM developer is now XBee code development package. It is self-developed in collaboration with the MaxStream ZigBee/802.15.4 RF module code.
Dec 12, 2021
So good
Nov 14, 2021
It works well
