3 Meter EL Wire (Gray Blue) is an electroluminescent lighting strand built from a phosphor-coated core sealed inside a flexible protective tube. When powered by a high-frequency AC voltage, this decorative lighting cable emits a smooth, continuous glow along the entire length rather than producing point light like LEDs. The slim 3 mm diameter and lightweight structure make this illumination filament easy to integrate into costumes, installations, signage outlines, and creative electronics. With a 3‑meter length and distinctive gray‑blue glow, this flexible light strand offers an efficient solution for creating vivid linear lighting effects in artistic and decorative environments.
Uniform 360° Linear Glow
This electroluminescent lighting cable produces a consistent luminous line across the full length of the strand. A phosphor layer surrounding the internal conductor emits light evenly when driven by an AC signal, eliminating hotspots commonly seen in LED strips. The smooth gray‑blue glow provides excellent visual continuity for outlines, edge lighting, and contour effects. Because the entire wire surface becomes a light source, this illumination filament is especially effective for highlighting shapes, creating glowing borders, and forming dynamic visual accents in decorative or artistic projects.
Flexible Structure for Creative Integration
A soft outer tube and thin internal conductor allow this decorative electroluminescent strand to bend easily around corners, curves, and complex shapes. The 3 mm diameter profile enables integration into clothing, props, model displays, and product outlines without adding significant bulk. This flexible lighting wire can be stitched, taped, or routed through channels for secure placement. Such adaptability makes the glowing cable suitable for wearable designs, stage props, exhibition displays, and DIY lighting installations where rigid lighting components would be difficult to use.
Wide Operating Voltage and Frequency Compatibility
This phosphor-based illumination wire operates across a broad AC voltage range from 20V to 220V with frequency support from 50Hz to 5000Hz. Optimal brightness typically occurs near 120V with a working frequency between 1500Hz and 2000Hz, allowing compatibility with many EL inverters and driver modules. Stable electrical characteristics—including defined capacitance and predictable power consumption per meter—support reliable illumination performance in long-running decorative applications such as signage outlines, themed displays, and architectural accent lighting.
Such electroluminescent lighting strands are widely used in decorative, artistic, and safety‑visibility applications. From illuminated signage outlines and retail displays to vehicle interior accents and costume lighting, this glowing cable enables distinctive visual effects with minimal power consumption. The slim profile and consistent brightness make this flexible illumination solution ideal for creative installations, event decoration, safety markers, and decorative electronics where elegant linear lighting is required.
Electrical Parameters
Physical Dimensions
